Motorcraft Filters According to uscar36 it's 95% @ 30 microns
Which may translate to around 80% @ 20 microns.Motorcraft Filters According to uscar36 it's 95% @ 30 microns
How can that be? Also now the Wix XP has something else on their website?Which may translate to around 80% @ 20 microns.
I keep my life simple... I go to Wal Mart pick up my Mobil 1 0w20 and a Fram 7317 Oil Filter go to the check out pay for it and move on....KISS Keep It Simple Stupid......
You're welcome JGmazda. You're using the data as it was intended; a holistic view of the choices and then deciding what matters most to you!Thanks for doing this! I still like the Microgard better. I suppose it's OCD etc... Some will say there are cheaper filters and "That's all I use and my car has 300+K miles"... But I look at the build quality. Price is not a factor when there's only a $5-6 difference. (A $15 plus filter better be cleaning my oil exceptionally well for the cost!) So really, it comes down to the quality and build and no nonsense marketing.
I always remember this classic:Which may translate to around 80% @ 20 microns.
Hi Nicasio,I like keeping things simple too. That’s why I try buy all my oil from Walmart as well, unless I’m looking for something more specific. It’s up to you if you like the OCOD as I just don’t trust it. If you’re happy with cardboard paper end caps do you. IMO, It would be stupid to pay more for that Fram vs the cheaper Supertech. I’ve read bad things about them over the years on a few other car forums I’m on. And you can see a lot of them being dissected on YouTube they don’t look that great… So I’ll keep buying the Supertechs for our daily drivers/5k mi OCI’s… As for all my other rarely driven cars that I do annual OCI’s on, I really like what I see in this MicroGard Select. It looks like really good quality for $11 a year. I’m much happier with that.
Look how the efficiency vs particle size curves behave (ref Ascent's test data graphs in link below). If a filter is 95% at 30 microns, it will be less efficient at 20 microns and even more less efficient at 15u, 10u, and 5u.How can that be? Also now the Wix XP has something else on their website?
Yes, but keep in mind that Motorcraft's USCAR-36 is a minimum spec, as well I'd bet is their "80% @ 20 micron" rating ... to cover all Motorcraft models I would presume.I always remember this classic:
When Fram changed the Ultra I started using Super Tech 20k filters. They are well made and not as media fragil as a similar priced Fram ($5-6). On my Honda I’ll run it 2 oci’s total, 18-20k miles.I like keeping things simple too. That’s why I try buy all my oil from Walmart as well, unless I’m looking for something more specific. It’s up to you if you like the OCOD as I just don’t trust it. If you’re happy with cardboard paper end caps do you. IMO, It would be stupid to pay more for that Fram vs the cheaper Supertech. I’ve read bad things about them over the years on a few other car forums I’m on. And you can see a lot of them being dissected on YouTube they don’t look that great… So I’ll keep buying the Supertechs for our daily drivers/5k mi OCI’s… As for all my other rarely driven cars that I do annual OCI’s on, I really like what I see in this MicroGard Select. It looks like really good quality for $11 a year. I’m much happier with that.
I wouldn't call the Fram PH orange can series of oil filters having "fragile" media. Seen plenty posted here that took lots of abuse and didn't tear.When Fram changed the Ultra I started using Super Tech 20k filters. They are well made and not as media fragil as a similar priced Fram ($5-6).
when you look at the Microgard select's o-ring it's a P-type instead of the squared off o-ring on the STP filter.. Not exactly identical, not trying to argue, just pointing out the differences. The Japaense OEM's like the P-type o-ring for it's sealing ability. I tend to agree. Another plus for Microgard!Ok so I swung by AutoZone and Oreilly's today (5 mins from each other) to pick up some fuel system cleaner and to compare the Microgard and STP filters. Both for 2022 Civic. Verified they are not the same. Also, STP is made in China and is $1 cheaper. STP looks identical to the Premium Guard.View attachment 160612
Yes, Microgard Select FTW!when you look at the Microgard select's o-ring it's a P-type instead of the squared off o-ring on the STP filter.. Not exactly identical, not trying to argue, just pointing out the differences. The Japaense OEM's like the P-type o-ring for it's sealing ability. I tend to agree. Another plus for Microgard!
I think that Toyota number is probably higher now. They recently switched to a different type of media.I always remember this classic:
Any official info from Toyota/Denso or other sources showing current ISO 4548-12 efficiency?I think that Toyota number is probably higher now. They recently switched to a different type of media.
I presume its an acceptable cross since Nissan makes both can sizes. I likely won't run this one - not sure?
The Pentius is going on next. I like it a lot. Assuming nothing bad happens I will buy a bunch more of it.I would run it if you already got it cheap enough and you aren't going to return it.. right ? .. Also the Pentius is really tough to beat IMO.
Whats the downside to running the shorter Parts+ filter. I run short OCI so I am not afraid of it getting full. Is there a higher delta P across the media since there is less of it - so your running in bypass more often - or ??
