Hi guys. I changed my oil 1k miles ago on my 2024 Cross Hybrid after seeing a milkshake under the oil cap. Thanks for the advice.
I heard recently how bad it is to over-tighten the filter, so i decided today to put it on ramps and loosen it a bit considering i recall turning it with the wrench after being hand tight. I cant say for sure how many turns i went.
The car's E-Brake applies automatically when in park, and disengages when put in drive. With this in mind, I couldn't figure why the car wouldn't drive up the ramp. The gas engine kicked in and I then realized the brake was on. Im not sure if my door was open or not.
Finally i got it on the ramps and removed the plastic cover. I noticed a bit of oil under the filter, but none on the cover. It had been 800 miles or so. I loosened it to hand tight with a wrench and planned to retighten it to hand tight. I did that and it spun until it seemed to hit a wall. It seemed pretty tight but i could tell it would go no more. This is a conventional spin filter.
I then wanted to start the car to check it under pressure. It was warm so the gas engine wouldn't kick on. I was stepping on the gas with the brake off and finally heard a crack. I realized i cracked the chock behind the wheel. This was not a good day.
I then backed up and the engine started. I tried driving up the ramps again, and the same thing happened. I pushed until the gas engine kicked on and realized the E-Brake was on again!
I shut it off and it went right up. Again, there was a couple of drops of oil at the filter's bottom.
Could I have stripped the filter for going a turn or two too much? It didnt seem super tight coming off although i needed a wrench to get it off. The threads were smooth. How fragile are filters? Would the filter strip before the housing?
Also, how bad was trying to drive a few times with the brake engaged on a CVT?
Ive been changing oil for 30 years on my cars, and thats about it (you can see thats my limit). Ive never had these odd issues before.
Thanks for making it this far! I appreciate it.
