TOYOTA OIL DRAIN PLUG GASKET
If 30 ft-lbs is too tight...what would you recommend? I checked the drain plug this morning after driving about 60 miles yesterday and sure enough it was loose again (I ordered new aluminum crush washers and have not received them yet). I torqued it to 25 ft-lbs and thought it felt really tight.
I bet that works. I pull the wrench evenly until I feel the crush. Around 30 #ft maybe? Dunno, but never a leak or loose drain plug.
I think you need a new oil pan. Likely have failing/damaged oil pan threads.
There was are ways to fix an oil pan with damaged threads.
Oversize oil pan drain plug that is self taping. Or some kits to re-tap the hole.
There is a Dorman rubber one with a wing nut that you turn to expand the part that goes in the hole to jam it in the hole tight.
But oil pans generally are not that expensive nor difficult to install except of course in a Ford 6.7 PSD.
I've had this issue on my 02 Camry and thought I was going nuts. In my example I got the washers off ebay so I blamed them for being knockoffs. After a couple iterations I reached under the car 1000 miles into an OCI and tightened the bolt then, so it's something that goes bad fairly soon after installation.
I recommend aluminum crush washers. Ironically I get the cheapest per unit price I can find on ebay. Yet they work fine.
Changing oil pans, IDK about your exact car, but usually you have to drop the exhaust and that opens a can of worms. Uncooperative fasteners, overextending the flexpipe and tearing it, etc.
Steel oil pans are generally not repairable. They use a welded nut on the interior wall; there isn’t enough material to perform any repairs.
Also, tapped threads are a poor fix for any fastener that will need to be regularly removed. The threads just aren’t that strong.
the two times I had to repair the oil pan drain plug threads, I was successful, but I did that with the oil pan removed and properly tapped the threads using the correct thread size and then made sure a new or good condition drain plug would go in completely by hand, and I did torque the drain plug to spec a few times before properly installing the oil pan back on the engine.
100%
One vehicles that I did the thread repair on, was a personal vehicle, on which I put on 60k miles after the repair, and never had issues.
I would only recommend someone try to fix the threads if they have some experience, and are willing to remove the oil pan and are able to test it before re-installing.
otherwise a new oil pan is the best way to go but I think the OEM Toyota oil pans are expensive, and I would trust my own thread repair over an after market oil pan.
Earlier this year, I went looking for some OEM Honda crush washers for my Civic. Yes, I know, I could have just driven to a dealer. Anyway, I was taken aback by the number of people selling counterfeit crush washers. eBay is the worst. Fake "Honda" logo tags everywhere. Gave up and ordered some "Mudder" washers from Amazon, figuring I can always return them if they look bad. Paid $6.50 for 50 washers, and quality looks perfectly fine. There are dozens and dozens of different companies selling parts like this on Amazon and eBay, how can anyone make any real money that way?
Toyota I purchased 8 Toyota Genuine gaskets for the fill plugs and drain plugs @ eCVT and Rear Differential.
The part number is 90430-A0003.
Thank you.
3 Toyota's, torqued to 27 ft-pounds.....
Fresh Toyota washer with the thicker felt part of the washer facing the pan(if you know, you know)......never an issue !
I purchase the same type of drain plug gasket from RockAuto in bulk. I believe they are from Ultra-Power, don’t remember exactly.
I’ve never ran into this issue. I used to use a torque wrench, but now I just tighten it, let out an audible “click click,” then say “that ain’t going nowhere.” I haven’t had an issues since doing that 😂.
If you don’t slap the oil pan when you say it you’re asking for trouble.
If u want an Over-the-Top gasket for the M12 drain plug. Perfect for a Fumoto valve application that experiences many heat cycles.
Rated for 3000 psi and 390F which is close to the oil’s flash point.
I used the OEM original blue crush washer filter for 3 years, 6 oil changes and eventually leaks. I replace it with aftermarket washer from Blueprint with black paint, it leaks from the first installation. I was too lazy to go to dealership and too cheap to pay shipping for such cheap washer and get it from generic blue rings in eBay.
It works but only can be used once. The blue coating peeled off. I finally bought Dorman 097-021CD Metal Rubber Drain Plug Fits 1/2, M12. I only use mild hand tight or about 10Nm and it has been good for couple oil changes. In the past, I used it for more than 7y in my 02 Altima
Go on Scamazon. They have like a 50 pack of plain ole crush washers that fit Toyota's. Cheap too. They look like the Honda crush washer, but don't loosen up like OEM Toyota. No leaks. Just punch you're model in and it will confirm fitment.
Scamazon baby...check it out. They are actual crush washers minus that crap Toyota puts on them. Perfect fit. Toyota does dumb things sometimes: Ex: Transmission pan and oil pan bolts dipped in loctite. Why would you do that ?!?! Mine rusted away. Needed new ones. That's how the new ones came. Just peachy !!!!!! Try to remove them again without rippin the threads out of the block or transmission case. Took a wire wheel on a drill, and wired off that crap. Ridiculous !!!!!!!!
