Again, idling a vehicle is apparently illegal in Germany but let's make other stuff unnecessarily disposable.Those silly Germans.
Clown world.
Silly ‘Merica/Mexico.Ford uses a "one time use" plastic drain plug on many F150's.
What could you possibly be keeping used crush washers for?I have replaced the plug on my 2005 Jetta a couple of times, but never understood the reason for it. I replace the copper crush washer every oil change. I have quite pile of used ones. Hondas use the same copper crush washer and I first got them from the Honda dealer in Spokane.
At a buck a piece, I’ll play along with changing out at every fill.I took a risk and bought these on Amazon for my VW. I use the proper tool instead of a flat tip screwdriver.
'18 GTI here. I bought one of those kits with the 'proper tool. It was made of plastic and lacked the ability to set the plug with the required torque. In other words the tool would twist and wouldn't set the plug. Back to a screwdriver. I do top side oil change and skip the plug, but they start leaking soon enough. Annoying to say the least. Really, the O-ring just needs to be replaced. But I haven't found anything suitable yet. Nothing from my HF stash looks correct.I took a risk and bought these on Amazon for my VW. I use the proper tool instead of a flat tip screwdriver.
In the case of a plastic plug makes sense. No metal replacement part?
3/4 turn past contact is the same whether you use a wrench or not.Don't overtighten the oil filter. Hand tight is good. You don't need (or want) to use a wrench to tighten it.
True, but doing it by hand pretty much guarantees it won't get turned tighter than that.3/4 turn past contact is the same whether you use a wrench or not.
Ground clearance issues with many VW/Audi/Porsche vehicles. Recessed fitting is one reason I like the VW Group plastic plugs.Install a Fumoto or Valvomax and be done with fooling with the drain plug.
While not exactly the same. I have blue plastic drain plugs in my boat engine's cooling system. They have an o-ring to make the seal. The snap after 2 or 3 years. I need to then get the broken part out and use a new one. Guess I would like something that does not snap every 2 or 3 years. The only good thing is they snap when you are trying to pull them at the end of the season so they don't ruin a day out on the water.Ground clearance issues with many VW/Audi/Porsche vehicles. Recessed fitting is one reason I like the VW Group plastic plugs.
I remember when I was under a '15 GTI I thought ignorance is bliss. Living in the country, you don't want to know how vulnerable that plastic pan appears. Just close your eyes, turn up the stereo and hope!Ground clearance issues with many VW/Audi/Porsche vehicles. Recessed fitting is one reason I like the VW Group plastic plugs.
The only reason would be arthritic hands.I see no need to use a wrench to tighten an oil filter.
