I came real close to over-tightening one once, and in fact I probably did to some extent. You know how it goes. lying down under the car in tight quarters, looking up sort of backwards to the bolt. Maybe using the left hand... Somehow the selector on my angle-head ratchet got switched from "loosen" to "tighten" and I was cranking down on that thing in the wrong direction! At some point, it dawned on me that I was turning it the wrong way. Fortunately no harm appears to have been done, and it has never leaked through several more years of use. 2002 Impala, aluminum oil pan.I once thought I over tightened a drain plug. I worried about it for five months. Turned out it wasn’t over tightened. I worried for nothing.
In other words: I think you'll be fine.
