Drain plug question - what actually is leaking, threads or mating suface washer to pan?
TiGeo
Virginia
I get weeping from the drain plug on my VW MK7 Golf Sportwagen. I have an aftermarket aluminum oil pan that uses an aluminum magnetic drain plug and single use aluminum crush washers. The recommended torque is ~20 ft lbs. Is the weep/leak from:
1) The threads (so you would say use HD teflon tape on them).
2) The mating surface where the crush washer should deform (I think?) to seal the drain plug against the pan.
Do I need to just tighten up (litterally!) and get that crush washer more deformed/tighten it more?
Don't forget folks, this post is set up on the forum using the "question" format so you can vote for the best answer with the arrows off to the right of folks' responses!
