- Joined
- Sep 10, 2021
- Messages
- 37
Hey all looking for some advice here. Long story short I stripped out the trans drain plug. I picked another one BUT the threads on the pan looked a bit worn so was EXTREMELY careful tightening it down. The plug did feel snug as if I had a good bite on the threads. Unfortunately it leaks a bit but its drivable and I can get to work. I dont want to risk stripping out the pan so I left it alone....and yes Im using a crush washer. Im going to give it another shot and try tightening it down again BUT in case I strip out the threads in the pan I want to be prepared for a possible repair so Im not stranded. I have one car and im basically preparing for the worst case scenario. Unfortunately I cannot find a oversized M10 plug and I looked high and low. I cant find a piggyback plug in M10 either. Looks like the next step is to tap to the next size up. My question :
Current bolt size is M10 X 1.5 Is the next size up M12 X 1.25 ?
I have never tapped a new thread before but Im confident I can do it. Will I need to drill out a larger hole for the next size up or can I just run the tap through for the new threads going from M10 to M12 ? Im worried about shavings in the pan so if I dont have to drill....I wont. Thanks in advance !!!
