Hi all, as you can see I'm new to the boards here, and I have a question about which oil is actually best for my 89 Toyota Supra turbo.
Toyota reccomends 10W-30 or 10W-40 from 0*F to (infinite)*F in the original owners manual. and 5W-30 for -20*F to 80*F weather conditions.
Now the enthusiast community swears on its life that the proper oil to use is 20W-50 synthetic year round. So I bought some Amsoil 20W-50 and I have been using that since I got the car a little over a year ago; and once warm the oil pressures are right in line with the Repair manual specs according to my aftermarket guage. More then 4.3psi at idle and a range (not sure of specifics at the moment) for 3k RPM.
Super Street as well had an article in which oil experts working for an oil company (I can't remember which one exactly) for a pro drag race team said that for the main bearing clearances that my motor runs, 20W-50 is the proper weight as well.
My car is not stock, I'm estimating I'm running about 300BHP from a stock 232BHP and my ultimate goal is 400BHP or just under.
I'm not the most in the know about all the advanced properties of the different weights of oils and which means what in the real world. So I was hoping someone could tell me that even though the main bearings according to the one tech and the community beliefs say 20W-50; if other parts of the motor (the head for instance) could have ports or tolerances that should run with 10W-30 instead. Or if oil has just become more advanced and higher weight synthetic oils can be used just as safely for the whole motor as dino oil from the early 80s of thinner weight.
Sorry for the long post but I wanted to give as much info as I could to aid in the answer. Thanks!
