- Joined
- Sep 28, 2002
- Messages
- 39,793
Quote:
If this means that for any decrease in viscosity, equal journal bearing protection can be obtained by increasing oil flow rate through it, this is one of the things that is not true. The eccentricity ratio increases (off-centeredness) due to the less viscous oil and what increasing flow rate would do is mostly: increase flow rate.
Now you're saying that that original offset will never be restored by increased volume? ..or (what you really implied) that the thinner fluid will always have this altered offset regardless of the volume applied.
That is, 1gpm with cold oil producing (let's say) 40 lb of back pressure ...that is reduced to 12lb of back pressure at hot visc ..has the same offset? ..and that increasing flow to produce 40lb of back pressure results in NO restoration of the offset toward how it was at the 1gpm, higher visc, flow rate?
(I'll continue to attempt text integration as we move on here. This, however, is the best medium for me).
