Originally Posted By: Bob The Builder
Originally Posted By: Bryanccfshr
The only place it can be "squeezed out" is in locations that are not pressurized. Such as Cam lobes and in modern engines these are relatively low pressure , low friction interfaces. And to tell the truth I see little reason why a more viscous oil is more protective in this situation other than it takes more energy to move it out of the way.
In crank bearings what seems to matter is having adequate volume to maintain a film.
You also reach a point of equilibrium where although a more viscous fluid may escape the bearing more slowly it is also replaces more slowly. As the fluid is thinned it escapes more quickly but is also replaced equally as quickly.
Frankly and without offending anyone named Frank, I have to politely disagree that oil can only be queezed out where the area being lubricated is not pressurized.
I saw a video, and dangummit if I can't find it right now, where an engine had a clear plastic oil pan. There was a camera set up under this engine. I remember specifically that the oil lubricating the crankshaft journals...which, and correct me if I am wrong, is under constant and high pressure oil, was spitting out along the journals. The oil has to go somewhere. It isn't only going to stay in the immediate area of the bearing. It was literally flying off of this crankshaft at a trmendous rate of speed.
I hope I haven't made an idiot of myself and either misunderstood the question or quoted the wrong post. Have a good weekend.
This is how the cylinders are lubricated, the oil slung off the crank from the rod journals. Oil most definately gets pushed out the sides of the bearings.
