2007 Mazda 3, 2.3L engine. The car is at 185K miles with basic oil changes at the recommended intervals, or sooner occasionally, but with “nothing special” discount-coupon oil changes for most of them. Almost all of them non-synthetic. There is no noticeable oil loss between oil changes.
In the last 12 months or so, the car has become noticeably less “peppy” than before. In the last two years or so, fuel economy has decreased from 26.5 to about 25 MPG
On the non oil side…
Some scan tool use and testing shows that the various sensors seem to be working reasonably well; however, the car is adding about 6% positive long term trim; so, I’m planning to check fuel pressure and will probably replace the injectors regardless (they are at the end of their expected life). The scan tool analysis suggests that the engine trim strategy is working as intended; so, that may only account for a bit of the sluggishness.
Cleaning and New Oil…
Beside double checking fuel supply, a track racer friend suggested an additional path of an “engine clean” and switching oils. That suggestion and some online content about Valvoline Restore and Protect and I’m falling into the oil “rabbit hole.” That in turn lead me to posts about product like HPL EC and BG EPR, etc.
So, now I’m wondering whether I should do quick "clean" with one of the shorter term products and then switch to a new oil like Valvoline R&P or Pennzoil Ultra Platinum for long term maintenance and ongoing cleaning.
That said, this BITOG discussion suggests to leave it alone: https://bobistheoilguy.com/forums/t...ys-a-good-idea-on-high-mileage-engine.390274/
I don’t think I’d be considering a clean cycle it if not for the performance issue. As for a better long term oil, that seems to be prudent considering we intend to keep the car for some time.
I’d appreciate advice on doing a clean, on a what to do for a long term oil, and recommendations for which products might be best.
