Obsolete grade/type: 5W-20 synthetic?
Pour point is something that I still have difficulty with. I may have some sort of a mental block when it comes to pour point.
ccs, mrv and pumpability aside, I keep thinking if you can "pump" two oils per spec and both meet the cold temp (winter) spec but one pours, drips or flows easier and can go through tiny holes and get to the moving parts faster ... then it must be better for the engine.
How much better? idk, it could be insignificant but according to many including Castrol, "Most (%75?) of engine wear occurs during warm-up ..."
Basically two same W oils "meet the winter spec" and are "pumpable" but one flows or pours/drips faster ... so I want that one!
Having said that, I use a lot of 10W-30 since the 10 is still well within my winter temp range. So I'm not afraid otherwise I would use 5W or even 0W. But if it was very cold and no block heater, given the same W rating, I would prefer the oil with better pour point. Maybe it's just a "feel good or better" type of thing.
Engine wear at warmup has little to do with oil flow and is mostly due to excessive fuel spray, moisture, and part clearances being way out of whack.
I'm still confused as to how a grade becomes obsolete, it may fall into disuse but it's not obsolete in the sense as no longer useful. The 900 MHz car phone in my old BMW became obsolete when there was no longer a cellular network to support its use. Analog television became obsolete when those signal transmissions were discontinued.
As far as I know many 10W-30 grades are API SP, so it's not as if they are API SG which is an obsolete API license. Most 5W-20 oils have most if not all the required licenses or specifications any modern vehicle might list in the owner's manual.
by warm-up I meant cold starts and the subsequent "warm-up".
The sooner oil gets to the moving parts the better. No?
As long as it is pumpable it gets where it needs to be. The winter rating is what demonstrates pumpability.
Yes, However, I am proceeding with caution. :)
For some reason I fell better if not in the borderline territory when it comes to the W. I like to have about 10-20F degree of margin. For example if 10W just barely meets my winter rating, then I move down to 5W.
If a 5W or 0W barely meet my winter rating, then block heater. lol
I may even use block heater if I was at the limits of 10W but I'm far from it.
10W will meet any winter requirement I've ever seen in Western Washington. I think your record all time low i Bremerton is 7.0°F.
And also down to the fact that the main antiwear additive in oil (ZDDP) doesn't really 'wake up' until it's warm, so you are relying on only hydrodynamic protection.
Oil pumps are positive displacement, so assuming an oil can pump then the amount that gets pumped will be largely unconnected to the viscosity. What does change is how much energy is required by the pump to move the oil, which will come out of the engine's available power - a thicker oil will put more drag on the engine and hence cause it to use more fuel to maintain a given speed.
The reason MRV was introduced is that it not only measures an oil's resistance to pumping, but it also, critically, measures an oil's tendency to form a gel-like structure when it has been cooled slowly. Oil with this structure will still pump but it can be enough to prevent the oil from flowing under its own weight, meaning that the oil pickup can suck oil from the sump and eventually create a crater in the surface which doesn't backfill itself, leading to oil starvation. This is what happened during some cold winters decades ago, so the MRV test was introduced which includes a detection for yield stress - if any yield stress is detected the result is a fail, regardless of the apparent viscosity.
@weasley
I think my problem is watching one video. These days i don't pay much attention to pour point when I buy oil. On top of that, we have mild winter temperatures and I am using mostly 10W.
Regarding the video:
I don't remember what engine it was but oil was pumped to upper parts of the engine and was dripping down through some tiny holes under I assume no pressure.
so I was thinking if oil A and B (with the same W rating) can be "pumped" but B flows slower than A and takes longer to get to where it is supposed to go ... which one would I prefer?
I am also assuming oil A has a significantly lower pour point temperature. Let's say dino vs. syn with the same W.
Maybe it's all insignificant but it makes me wonder.
A 5W-20 is going to have somewhat less VIIs than a 0W-20, so I suppose that if you're in a climate with milder winters it might be a bit more shear stable. But if it gets very cold where you drive you're going to want the better low temperature pumpability I would think.
If you use the same type of base with lower viscosity in the 0W-20 that's true but often the 0W-20 has a higher VI base stock and in that case may have less VII. I've often thought the issue might be a concern about the VII in the few 0W-20 Blends available.
I personally would not be afraid to run 0W-20 (5W-20 spec vehicle) but would be selective about the ones I chose.
However, expecting the average consumer to deviate from whatever is on the oil cap is not something I see happening in any great numbers so I don't see it becoming obsolete anytime soon. 10W-40 isn't yet obsolete and it's been a while since new cars have specified it as the primary grade.
