you will have better overall lubrication running the 5W-30
Can you elaborate on this? I can't see how this would be the case. Perhaps he'd had 0.001% better fuel economy, but I don't think that a 5w-30 is going to provide "better" lubrication than a 0w-40, particularly not M1 0w-40, which has more manufacturer certs and approvals than any other oil they make.
For the same reasons, M1 5W-30 is a better lubricate choice in the 638 HP Corvette ZR-1 than M1 0W-40.
For daily driver duty perhaps one could argue that it is a
more appropriate choice for the oil temps encountered. For track use GM runs M1 0w-40 in their own Corvette Program cars.
You've answered your own question.
The specified M1 5W-30 is more appropriate for street use which is what we're talking about here.
More appropriate for an application based on daily driver oil temps and an imperceptible increase in fuel economy doesn't equal "better lubrication", which was what you stated. I don't believe I answered my own question at all. All I've done is identified GM's reasoning for recommending their "across the board" synthetic oil (M1 5w-30) in the ZR1. That doesn't mean it provides "better overall lubrication", if it did, they'd run it in GM's Corvette Program cars, but they don't, they run the 0w-40, likely because under all of the conditions encountered with THOSE cars, the 0w-40 DOES in fact provide "better overall lubrication". If it didn't, they wouldn't use it. Simple as that.
The 0w-40 has a more robust additive package, better longevity, better base stocks, and in general is just a better oil than the 5w-30. The only difference is that it is a bit heavier. I mean I guess it is easy to discount the insane amount of durability, wear control, deposit control....etc testing that it had to go through to gain the Porsche, Mercedes, BMW, Audi....etc approvals, the fact that it is used in a myriad of actual race cars, used by factory race teams.....blah blah blah. And assume that because it is a few cSt heavier that it must provide "inferior" lubrication right?
I don't see how it is possible for you to legitimately back-up the statement "better overall lubrication" here. Perhaps if you had said that the 5w-30 was more appropriate based on oil temps observed in your average street car and that the 5w-30 offers a more appropriate operating viscosity and should provide slightly better fuel economy, sure. I think we can generally agree that your typical street car that spec's 5w-30 isn't going to see any sort of notable benefit from running an oil that is heavier than spec and likely, while being a bit heavier on additives, isn't going to provide any measurable increase in wear control over the spec lubricant. With those qualifiers noted I would argue that neither oil is going to, under these operating conditions, offer "better overall lubrication" than the other. Simply that the 5w-30 is more than adequate for the expected operating conditions and there is no real benefit to running the heavier-than-spec oil unless the operating conditions are somehow exceptional in a way that has not been described to us and that elevated oil temperatures have been observed.
