That looks like some sort of NIC at some point isn't negotiating gigabit speeds and running at 100Mbps. That is not right.For comparison, I'm supposed to be getting 1000 Mbps, this is my actual speed:
View attachment 196198View attachment 196199
Forget high throughput on the 2.4GHz channels, it's just not possible.I have the router configured to have both 2.4GHz and 5GHz networks, on channels 6 & 153 respectively. On the 5GHz wifi, the maximum download speed I can achieve is 250mbps, and the 2.4GHz maxes out around 80mbps. What gives?
Should I call Xfinity and complain?That looks like some sort of NIC at some point isn't negotiating gigabit speeds and running at 100Mbps. That is not right.
How much bandwidth did you allocate to your 5GHz channel?FWIW, I have Spectrum rated for 500Mbps down by 20Mbps up. Using a Ubiquiti EdgeRouter X SFP and a single Aruba InstantON AP22 in my attic. I'm sitting on my couch on my 2019 MacBook Pro one floor down.
Is all of the equipment theirs? If so, then yes, that is seriously underperforming. Should at least be hitting 300-500 on modern devices and equipment.Should I call Xfinity and complain?
No, not until you know which WiFi standard you are using and how much bandwidth is allocated to your channel. If you are on 802.11ac, 1Gb/s throughput just isn't going to happen. With an 80MHz 802.11ac channel, you'll be lucky to get 500Mb/s sustained.Should I call Xfinity and complain?
But I think we both can agree that even with knowing very little about the poster's setup, if they're running Xfinity equipment, which barring a major end-user equipment change or reconfiguration (Xfinity will provide equipment to support the 1Gbps tier) and what appears to be a modern MacOS version... 75-85x10 is pretty far off. Unless poster is a far away from the AP and going through 6 walls and falling back to 2.4GHz.No, not until you know which WiFi standard you are using and how much bandwidth is allocated to your channel. If you are on 802.11ac, 1Gb/s throughput just isn't going to happen. With an 80MHz 802.11ac channel, you'll be lucky to get 500Mb/s sustained.
I do not limit bandwidth on my main hidden SSID. My IoT SSID however is called at 3Mbps and is 2.4GHz only.How much bandwidth did you allocate to your 5GHz channel?
How do I find out which WiFi standard I'm using and the bandwidth allocation?No, not until you know which WiFi standard you are using and how much bandwidth is allocated to your channel. If you are on 802.11ac, 1Gb/s throughput just isn't going to happen. With an 80MHz 802.11ac channel, you'll be lucky to get 500Mb/s sustained.
Understood you don't limit, but how much bandwidth (channels) do you allocate to your 5GHz radio?I do not limit bandwidth on my main hidden SSID.
Yeah, I agree something isn't right. I would just like to understand which WiFi standard and how much bandwidth is allocated to the channel, so we have the right expectations.But I think we both can agree that even with knowing very little about the poster's setup, if they're running Xfinity equipment, which barring a major end-user equipment change or reconfiguration (Xfinity will provide equipment to support the 1Gbps tier) and what appears to be a modern MacOS version... 75-85x10 is pretty far off. Unless poster is a far away from the AP and going through 6 walls and falling back to 2.4GHz.
Either log onto the router or look in your adapter config on your PC.How do I find out which WiFi standard I'm using and the bandwidth allocation?
20, 40 and 80MHz. Limit of the AP22. I guess the new AP25 do 160MHz. But I also hear they run super super hot.Understood you don't limit, but how much bandwidth (channels) do you allocate to your 5GHz radio?
From your throughput, I'm guessing you have 802.11ac with an 80MHz channel.20, 40 and 80MHz. Limit of the AP22. I guess the new AP25 do 160MHz. But I also hear they run super super hot.
So now we're getting into stuff I'm not sure on.How much bandwidth is allocated to the 5GHz channel? What 802.11(??) standard?
You can get > 1Gb/s sustained throughput on 5GHz (ax) with 160MHz bandwidth allocated to the channel. I do it every day.
Without an 80MHz channel option, I'm betting you are on 802.11n. If that is the case, you're not going to get much better than 200Mb/s.In the router settings for 5GHz, for channel width, my options are Auto, 20 MHZ ONLY, and 40 MHz.
