Asus RT-AC66U B1 wifi speeds vs WIRED speeds with NEW Modem and New Plan (Spectrum 1GB)
I'm afraid 450-500 Mbps is about the best you can expect from this router over wifi, under ideal conditions.
https://www.smallnetbuilder.com/wir...band-wireless-ac1750-gigabit-router-reviewed/
https://www.pcmag.com/reviews/asus-rt-ac66u-b1-dual-band-gigabit-wi-fi-router
Those charts are for the original AC66 which is a lot slower than the newer B1 version.
Its still wifi 5, 99% of all clients are only 2x2 your not going to do much better then 500-600 mbps with that i don't care what router it is. Plus the AC66U B1 only has a 1ghz processor by todays routers thats slow.
You are right about WIFI 5, but it doesn't explain why OP was getting slower speeds than he was previously.
Thanks again for all the input. Trying to do some research and came across this router: seems to have very good reviews and features.... some of which I will never need/use but sort of future proofing, I guess? Never heard of this brand before, BTW.
The flint 2:
https://www.gl-inet.com/products/gl-mt6000/
Even the lesser Flint might be enough for my needs? Price is better, too:
https://www.gl-inet.com/products/gl-ax1800/
Looks like they are based out of Hong Kong.
What's your budget?
All routers will have features that 99% of us will never use. I'm a nerd/geek and other than inputting custom DNS, my routers run pretty much with the default settings.
Never heard of that brand router though....
The GL-MT6000 has a powerful chipset which will blow the doors off of the MT7621 you have now in your AC66. It will also run generic OpenWrt if you are concerned about the manufacturer firmware.
You can always look for online speed test of various new routers.
Many websites do this and the cool thing is if you order from a place like Amazon, Walmart or even Best Buy, with Best Buy check the return policy.
You could even try out a whole bunch of these things, you will get your answers to your speed question and if you’re not happy with it, just return it. Free returns.
Actually, you can order a couple of them and keep your favorite one.
https://www.tomsguide.com/best-picks/best-wi-fi-6-routers#section-the-best-wi-fi-6e-router-overall
Technically, you can simply add a Unifi AP wired into your modem, no real need for management console, this will be a cheaper solution, all you need is to buy an AP (access point).
Or just be hardcore like me and get an Asus ROG Rapture GT-BE98 PRO then hardwire mesh nodes! In all honestly, don't get that router. You most likely don't need it. I don't need it, but I wanted it and I paired it with 2 Asus ROG Rapture AXE11000 routers used as mesh nodes with wired backhaul at 2.5Gb.
Anything recommended above will work for you. You can always replace your router if you want simplicity but there are cheaper ways too.
For friends who have wireless dead spots and have the money, I usually recommend Netgear Orbi systems. They aren't cheap but they are solid. My Asus stuff needs to be rebooted once in a while. They do stupid things like loose internet connections (wireless and wired) or just the other day, it was telling me that some devices had to log into the router. A reboot solved that. But, being in IT, I can deal even though it isn't ideal. I also bind certain devices to certain nodes and after the latest firmware that is a bit wonky.
My parents and son have EERO systems that were provided by the ISP. They actually seem to be pretty solid. One with GB fiber and the other with 500Mbps.
