Funny video from a Florida mechanic having to deal with below-freezing temperatures ... in Florida![]()
Don't know, don't care. Only the first 2 minutes were the relevant part.so if its a 2021 why is he running sludge cleaner? or did I miss a joke? I did stop at 3min in it was hard to watch.
But people in Florida, S California, south TX, etc will still insist how horrible and unnecessary it is to warm cars up.It's currently -4 degrees Fahrenheit where I'm located. The lows tonight is forecast to be -22 degrees Fahrenheit.
In the South , yes it is .Don't know, don't care. Only the first 2 minutes were the relevant part.
But people in Florida, S California, south TX, etc will still insist how horrible and unnecessary it is to warm cars up.![]()
Itās not required.Don't know, don't care. Only the first 2 minutes were the relevant part.
And that's fine, but it's not the case here or everywhere.In the South , yes it is .![]()
Parked in your garage ? If not, what kind of defroster does your vehicle have ?-30C here (-22F), started, gave it 30s and drove off. OMG! The horror!
Nope. If you actually keep the inside of your car dry, you should never have frost on the inside of your glassā¦ever.Parked in your garage ? If not, what kind of defroster does your vehicle have ?![]()
Yep, if itās dry inside you wonāt get frost on the inside. Though I prefer to bake the moisture out, I like the cabin at a cozy 80-85F in the winter! Though I also refuse to wear more than a hoodie when I driveā¦Nope. If you actually keep the inside of your car dry, you should never have frost on the inside of your glassā¦ever.
Pro tip, leave a window cracked when you park to let the warm, humid air out, so it does not condense on the cold glass. I try to always park with the sunroof in the vent position, unless there is a forecast for significant snow. Never get frost on the inside of my glass.
I don't let it warm up more than a minute until it gets down into the teens and single digits, however long it takes for the idle to drop to 1k. 30 degrees is not that cold.Don't know, don't care. Only the first 2 minutes were the relevant part.
16 minutes today ā¦ā¦ā
The video is from Florida - that is very cold for them.30 degrees is not that cold.
Not talking about frost on the inside of the window(s).you should never have frost on the inside of your glass
Same here. I don't drive with a heavy winter coat, gloves, hat, anything.Though I also refuse to wear more than a hoodie when I driveā¦
Only time that I have that problem is when you get a lot of snow on the floor of the vehicle and the outside conditions are just right.Nope. If you actually keep the inside of your car dry, you should never have frost on the inside of your glassā¦ever.
