...I say maybe...depending on whether they fit...
I got a line on these rims...17"ers up from the stock 15s....photoshopped here (on top) for comparisons....
They are 35 or 38mm offset (depending on different sites' specs)...VS the 50mm offset of the OEM wheels, it should be just about the right fit...
Whadahyathink.....?
I suppose I could add a spacer if necessary...
Here's a comparison of specs using a 205 (rather than a 215 tread/section width of the OEM/17s on other models)...the results are nearly identical to the 15" I have now...so I'd be safe with the 205 if a 215 (OEM on the Solara) wouldn't fit...
