4WD
$50 site donor 2024
Scott - should of set up a Slido survey
There's no car payment on this car. We don't have debt of any kind, not even on the house.I really hope there is no car payment on this car. How is it driven only a few hundred miles per year? What is the point of having so much money tied up in a depreciating possession? (not going to foolishly call it a depreciating asset as that's definitely an oxymoron) Sell the entire kit and put the money into a better option. But to answer the question, the BMW wheels are the only answer.
My E46 came with the optional Style 72 wheels. I sold those long ago. As far as the Style 225Ms I might sell, many people confuse those for the Style 135 wheels that came on ZHP E46s. The Style 225Ms were an optional wheel for the E90/E92 cars.I'll add that if those are indeed (as i understand it) the factory OEM wheels for a ZSP i would NOT sell them without the car.
Thanks, Ed. And they really are in BNIB condition - with a set of 1,000 mile old Cup 2 tires.First off, there is no wrong choice here, both options are correct. I absolutely love the BBS wheels on those cars. But I would probably keep the 225M wheels since I am sure those BBS wheels will bring in a decent amount of money from the right buyer.
My oldest son jokes with me and says when I pass on he's going to hack it up and put a small block Chevy in it.Some day this car is going to sell to another BMW aficionado /collector and since the correct as bought BMW wheels are gone IMO keep what you like best. Now leaning to the BBSs since they and the tires are a higher performance package correct for the car. Glad to help.
Shut up KarenI really hope there is no car payment on this car. How is it driven only a few hundred miles per year? What is the point of having so much money tied up in a depreciating possession? (not going to foolishly call it a depreciating asset as that's definitely an oxymoron) Sell the entire kit and put the money into a better option. But to answer the question, the BMW wheels are the only answer.
Strange as it might sound, the difference in the wheel/tire weight is noticeable in daily driving. IIRC the BBS wheels are 5 to 7 pounds lighter, front to rear. Also too the Cup 2 tires are a pound or two lighter than the P4S tires.Keep the 225M. 1) They make the car look faster . I realize that is very subjective. But that is my opinion. 2) As nice as you have kept this car, I can see why you say it is a little of a museum piece. It seems the BMW wheels add to that. 3) Someone mentioned weight. Considering what you have shared, of how you drive and care for this car, I don't see the weight being a factor. Sure, if you were throwing it around a track, trying to get extra 2/10ths of a second, it would matter. But you are never going to do that, right?
IMHO, very few aftermarket wheels actually enhance the look of a car. They just look like bling. The BBS CH wheels do look nicer than most, but they just don't quite cut it for me.
You have a good eye! This is because of the combination of offsets and widths - but mostly tires.OH I like those even better.
Still say the 225s out of the two you have. I do agree with the poster that said both sets seem a bit too large... I still think the difference in the front wheels is the key, while the rear CHs look sort of tucked in, the fronts don't... the 225s look even...
Eibach Pro-Kit Springs
Bilstein B8 Struts/Shocks, E36 M3 Versions On Rear
BMW Motorsport Front Strut Tower Reinforcement Plates
Rogue Engineering Rear Shock Mounts
H&R Sport Adjustable Anti-Roll Bars, 27mm front, 21mm Rear
Turner Motorsports Adjustable, Ball Jointed Front Anti-Roll Bar Endlinks
Mason Engineering Adjustable, Spherical Bearing Rear Anti-Roll Bar Endlinks
BMW M3 Front Strut Brace
BMW ZHP Front Control Arms
BMW M3 Engine Mounts
BMW M3 Transmission Mounts
Meyle HD 66mm Front Control Arm Bushings
BMW M3 Rear Control Arm Bushings
Turner Motorsports Rear Control Arm Bushing Limiters
BMW M3 Spherical Bearing Rear Lower/Outer Control Arm Bushings
Stoptech Stainless Steel Brake Lines F/R
BMW Motorsport Cross-drilled, Fully Floating Front Brake Rotors
Jurid Front Brake Pads
BMW M3 Rear Brake Pads
Turner Motorsports Brass Brake Caliper Bushings
Borla Catback Stainless Steel Exhaust
Meyle Heavy Duty Rear Differential Mounts
BMW ZHP Finned Rear Differential Cover/Cooler
BMW ZHP Shift Knob
B&M Short Shift Kit
UUC Stainless Steel, Weighted Shift Rod
Mason Engineering Quick Shift Geometry Clutch Pedal Arm
Stewart Engineering Water Pump
Rogue Engineering Underdrive Pulley Set
BMW M3 Trunk Lid Spoiler Lip
BMW Motorsport Alcantara Steering Wheel
Center Arm Rest Delete
A good friend of mine, I was a groomsman, just finished a project that is similar but not a hackjob at all. It is a E39 wagon with a 427CI LS3 and a 4L80E. The LS runs off a Holley ECU with a box that lets the Holley and BMW CAN systems communicate so all of the BMW side electronics work. Its a really clean swap, if you are ever in the area you would get a kick out of it. The only outward signs something is up are M5 wheels and it has KW coilovers. Then he starts it up and even with 2 cats and 4 mufflers it is louder than my Mustang.My oldest son jokes with me and says when I pass on he's going to hack it up and put a small block Chevy in it.
You mention it going to an aficionado or collector. It's been fully documented from day one. These are fully stuffed 4 inch thick binders, not the thinner ones. I even have the bottle of wine the dealer gave me when I took possession. My name is engraved on the bottle!
Scott
