changing tire size
On my 98 mustang I picked up a set of 16 inch wheels from a 2006 mustang that I am going to use on it. Tried the wheels and fit perfectly, but the stock size on the wheels is a 215 width. The stock width on the 98 is 205. I am going to buy new tires for it as the tires on the wheels now are wore out. Just making sure that it will be ok to use 205s on these wheels.
NE,Ohio
what is the width of the new 16" wheels?
Just a guess but going down 10mm in width is usually ok on any wheel.
you would take the rim width and compare it to the spec sheet for the tire you are purchasing. it will give a range of acceptable rim width.
tirerack is handy for tire specs.
Daytona Beach
I think Tire Rack or one of those websites have a size comparison/fitment chart. It even tells you how much it will impact the speedometer difference.
Virginia
Upper left, click on the tab “Tire Comparison”
NE,Ohio
not applicable hes talking about running the stock tire size.. just on wheels from an 8 year newer mustang.
