New tires for my VW
Retiredville SC
The follow-up to my good experience at Discount Tire thread. So Dad got some new shoes. Slapped them on and went out for a ride. Not broken in yet, but can feel they stick like chewed bubble gum on hot asphalt. First few miles I could tell much quicker transient response and braking traction. Just a tad harsher than the 235/40-18s they replaced. Think this will be fun.
OK, but, what tires? :)
Guess you had to follow the whole adventure.
First, posted in the Continental Tire rebate program thread. These are the 235/35-19 Continental ExtremeContact Sport 02s that I ordered as part of the program. Then, I started the thread about having them mounted and balanced at Discount Tire, at which, I had a very good experience with. Wrapped it all up with this thread. Thanks for playing along 😁.
Aaahh, OK. Did not follow that.
Yeah, let me know how that goes. I am running DWS06+ now, and while a very good tire, I'm a bit irritated with the soft sidewalls. And running those bcs. with changing weather here, AS tires are really the best bet in May, June, or September, and in October. But I miss those max performance summer tires. That "glue" feeling. So thinking that tire or Michelin PS4S next year.
DWS 06+s are my other set that these replace for the warmer months. Not that it gets really cold here, but many nights and mornings under 40F, so summer tires don't do so well. You nailed it, the DWS are great tires except for the soft sidewalls. Makes for a comfy ride, but not super direct with transient response.
Contis are great rubber. I bet you will love 'em on your Dad's VW.
It's my car, I just call it Dad for short.
Excellent, you have both. So how are sidewalls on 02 compared to DWS?
Well, seeing that the Sport 02s are a 35 aspect ratio, and the sidewall is only about a half inch shorter that the 40 aspect ratio DWSs I use, there really isn't much vertical difference, so you'd think they would be close in stiffness. However, when the the 02s were mounted, you could see the sidewall was much thicker in cross section compared to the DWSs and that increases the stiffness. The part of the mounting machine that holds the sidewall down as the tire was guided onto the wheel really has to apply quite a bit of force because those sidewalls are so stiff. The sidewalls of the DWSs are floppy fishes in comparison, but momma prefers the ride of these on her Tig. She no Speed Racer 😁.
Yeah, i keep DWS 4psi over what they should be. Still so so. Going fast through curve doesn’t offer any feedback and steering is mushy. You can feel that tire is really holding onto asphalt, but correcting it in case of oversteer is more based on guessing than real feedback.
The general as-07 are somewhat stiffer than the dws06+.
although hard to compare since I have 2 wildly different sizes and vehicles.
The ExtremeContact Sport 02 are next level... But I dont run summer tires too much wacky weather in ohio. I'd imagine Colorado is worse.
I replaced the DWS 06+s on my son's Jetta GLI when they were worn out (52K) with the new(er) Pirelli P Zero AS Plus 3s. Even though Tire Rack's catagory chart shows them to be extremely close in rankings, I could definately tell the Pirellis were MUCH better with steering response over the Contis. The Pirellis have 1 more reinforcing ply in the sidewall construction than the Continental and that increases the stiffness without making for a harsh ride. I really like them.
Colorado is difficult bcs. changing weather. I run snows November-April.
May is the one where things are crazy, as well as October. 80 degrees? No problem. -10? Also no problem. Then in between is drought and monsoon season.
Winter is the one that is steady. Cold enough not to wear them out regardless of abundance of sun, when ski anything can happen, and since I live at 6,800ft weather forecast is 3”, but in reality 0-2ft.
I tried cranking up the air pressures, which helped a little. But the solution was different tires...and I prefer the better grip of summer tires in dry and wet anyway. We rarely get snow where I am.
The snow is not an issue as I run snow tires. It is several months of very wild weather after and before winter. June, July, and August are usually excellent for summer tires. I mean, I have two other cars. Will probably just get 02 or PS4S next spring.
Yeah, I run 4-5psi over, depending, and it is better, but it is just a band-aid, as you said.
Give the Contis a try. Every Michelin sport tire I've had gets really noisy after 5/32s or so. They seem to lose some of their soft gripiness too and wet traction really falls off IMHO.
IDK, Michelin PSS were best tire I ever had, period. I mean I had numerous Continental summer tires in Europe. DW and DWS are US market only.
PSS was cutting through rain at 3/32 better than some new tires, and still holding like a glue.
