Some here are using an oil filter for 3 changes and others are taking apart brand new ones. I'll never understand this place, hah.
If u look up on the Premium Guard's website for the Ultimate Synthetic filter, it says both.If it's black silicone, it needs a burn test to verify.
The Carquest Extended Performance with a black base gasket says this on their website:
Can you share/add a picture of the gasket?
They say silicone gasket and hnbr which is a type of nitrile. Writer error I suppose. No one is perfect.If u look up on the Premium Guard's website for the Ultimate Synthetic filter, it says both.
https://www.pgfilters.com/products/filters/oil-filters/ultimate-synthetic-oil-filters/
The N in HNBR is Nitrile (Hydrogenated Nitrile Butadiene Rubber).If u look up on the Premium Guard's website for the Ultimate Synthetic filter, it says both.
MaxLife is oil.View attachment 333868
Thought this was interesting. New packaging/vendor must have names/descriptions thrown off.
I'd be stunned if it's not the same filter in different livery. Good to know.Looks same/similar to CarQuest EP filters.
99.5% @ 25u
I think you got the smoke color backwards per your photo in this previous BITOG thread.The N in HNBR is Nitrile (Hydrogenated Nitrile Butadiene Rubber).
A burn test should produce black smoke instead of white smoke if it really was silicone.
If it's nitrile, black smoke like I said above. Since it says it's HNBR, then:I think you got the smoke color backwards per your photo in this previous BITOG thread.
I read it this way:If it's nitrile, black smoke like I said above. Since it says it's HNBR, then:
"A burn test should produce black smoke instead of white smoke …"
Yeah, not written perfectly clear, but the bottom line is:I read it this way:
Let's eat GrandmaMaxLife is oil.
Max Life is filter.
Right?
I thought the same of new filters cut open as well, but then I realized there’s a benefit to seeing an unused filter vs used. And after that realization, I bought a filter cutter and contributed a few new filters myself. It’s all for the BITOG community. And I consider myself only a hobbyist.Some here are using an oil filter for 3 changes and others are taking apart brand new ones. I'll never understand this place, hah.
I see white filter paper so I think it might be more like the Carquest EP...
