- Joined
- Jun 1, 2025
- Messages
- 37
Just bought and cut a new STP S7317ML (Vietnam made) oil filter. It's a recently updated full synthetic filter, supposedly made by Premium Guard (at least, with many parts from Premium Guard). STP Max Life oil filter/Max Performance used to be made by Champion Labs, which is similar to Fram Endurance, Amsoil EAO, etc.
The updated version has internal parts that look very similar to the Carquest EP (full synthetic filter made by Premium Guard). It has an integrated bypass valve, which should prevent the leaf spring leaking issue on some older Champion Labs-made filters. What's interesting is that the filter media does appear to have a black metal wire backing. The filter also has a metal crimped joint. The casing looks like the older version, with a welded nut for removal at the bottom.
Autozone has also updated the pictures and description for the new filters. However, there are still many older-version filters in stock at local AutoZone. Beware if u want to buy the new version.
