In most cases, all it does is benefit the next home owner.^^^^^^^^This^^^^^^^^.... is the way to go nowaday
I would said something.With pneumatic nailers, power ladder hoists and migrant labour - the cost should be less not more. I do suppose the tear off debris disposal rates have gone up in some places so you would have to fold that cost back in.
Three roofing Co's I talked to said they can't get any domestics to do the work. I really wanted to say you have to pay them appropriately and fairly, but I bit my tongue.
I did just that with a local "in town" company, In the past The owner and a couple workers used to be on the jobs site. Now the guy is off cruising the coast in his new 'vette (not my words but words of the contracted roving domestic estimator) and the job was completely sub contracted out to migrant labour. They were quick professional; and did a great clean-up job and ... they didn't flatten the shrubbery.My only advice is go with a local company that has been around for awhile....They will still be around if you have issues down the road...Dont go cheap on a roof...
My friend hired a local contractor for Hardie board siding. $45kI did just that with a local "in town" company, In the past The owner and a couple workers used to be on the jobs site. Now the guy is off cruising the coast in his new 'vette (not my words but words of the contracted roving domestic estimator) and the job was completely sub contracted out to migrant labour. They were quick professional; and did a great clean-up job and ... they didn't flatten the shrubbery.
You have to multi quote. I estimate matrails and labour and demolition dumpster haul away. If the excess over charge surcharge is insane, keep looking - unless you just like throwing money away for nothing.
The roofing job must be warrantied for replacement without pro rating for many decades.
The "metallic" noise doesn't transmit well through the roof decking at all. There's a tiny bit more noise, but you really have to listen for it to even notice.What about the noise when it rains?
7 grand in materials for primed Hardie cement lap siding (Ten bucks a .65' x 12' plank)My friend hired a local contractor for Hardie board siding. $45k
Demanded the owner be on the job. He was there for 2 days only and my friend was happy because the owner did the worst work.
When the subs took over the quality went up..
Big house, painting, windows, doors,and termite damage and so on.7 grand in materials for primed Hardie cement lap siding (Ten bucks a .65' x 12' plank)
Man that's enormous labour an overcharge costing.
Owner be paying Alimony x2![]()
If you had a quality metal roof, you would need no inspections. My 21 year old metal roof looks and performs the same as it did the day it was installed.My only issue with metal roofing is that it makes your roof slippery. At least with shingle roofs you don't have this issue. If I had to go on a metal roof I would want a permanently mounted stainless steel anchor point and a harness. I got on the roof at least once per your for my inspections and I do my own repairs.
I would have said something.Three roofing Co's I talked to said they can't get any domestics to do the work. I really wanted to say you have to pay them appropriately and fairly, but I bit my tongue.
Snow slides off. Only problem is, if you get a lot of snow, it piles up on the ground along the house, possibly, based on the house design, blocking access to external doors.
Good luck when its a 2 foot snow fall !!
It's cheaper then a gym membership.Good luck when its a 2 foot snow fall !!
You should not be on a roof in first place without proper anchor.My only issue with metal roofing is that it makes your roof slippery. At least with shingle roofs you don't have this issue. If I had to go on a metal roof I would want a permanently mounted stainless steel anchor point and a harness. I got on the roof at least once per your for my inspections and I do my own repairs.
