New oil: Fuchs TITAN Supersyn LONGLIFE SAE 0W-40
OVERKILL
$100 Site Donor 2021
Ontario, Canada
Just saw this on their website!
http://www.fuchs-europe.com/products/lub...passenger0.html
TITAN Supersyn
LONGLIFE
SAE 0W-40
Ultra High Performance, fuel-economy engine oil for a variety of vehicles with or without extended service intervals. Excellent cold starting and lower oil consumption.
ACEA A3 / B4
API SN
Approvals:
MB-APPROVAL 229.5
PORSCHE A40
Recommended for:
MG
ASTON-MARTIN
BMW LONGLIFE-01
FORD M2C937-A
Requesting a copy of the PDS right now
Current list of their oils for those interested:
http://www.fuchs-europe.com/fileadmin/fu...r_2-2013_GB.pdf
Odd that it's called "longlife" just like the BMW approval, but it isn't formally approved. They also didn't go for VW 502/505.
No "XTL" in the name either...
Nope, the XTL oils don't have a 0w-40 or an LL-01 oil IIRC
They do have XTL in both 5w30 and 5w40 LL-04 oils, which meets LL-01.
Isn't LL-04 low-SAPS though? or at least mid-SAPS? I was under the impression that LL-01 was full-SAPS
AFAIK, only Fuchs GT1 mid/low Saps formulas have XTL technology.
Supersyn is full Saps (LL01)
GT1 is mid/low Saps (LL04)
They seem to recommend GT1 over the Supersyn, even for my '95 Fiat, GT1 5w40 is their prime recommendation.
Yes, but I thought that all LL-04 oils are okay to use in LL-01 applications? BMW has even spec'd some LL-04 oils for LL-01 cars; for shorter intervals I wouldn't be worried.
Originally Posted By: dailydriver
I'd be very interested to see the specs on this once you get them!
I suspect it will be HTHS of 3.6 or 3.7, with a VI in the mid-170s. Probably a TBN around 10.
If someone will sell it to me for $5/qt delivered, I'll buy it.
That's the problem with any oil brand when you can buy M1 0W40 5-qt for $25. It's very very difficult to find a better oil for the same amount or less.
If you don't have WM around (very few people do) then normal price of $8-9 a quart at auto pats store can be beat.
Originally Posted By: supercity
Maybe we should give M1 a handicap, just to give the others a chance.
If you're outside the US, it does seem to have a massive handicap -- price.
In Germany and other EU countries you can get it onAmazon for the same price as Castrol or SHell.
However, Castrol i the EU is MUCH better the Castrol in the US, so there is no that popular belief that one is so much better then the other one, nor you have just one Castrol that is premium product (GC).
What is your definition of a "premium product"? If you go by the specs it meets, then Castrol Edge 0w-40 that we have here should also be considered a premium product.
Well, yeah, I forgot about that one:)
Yes, sometimes it amazes me that some the (exorbibtantly priced here) 'boutique' oils are actually less costly than M1 in some of these countries, especially in the Antipodes/S-Pac island area.
Fuchs 0w-40:
Code:
Density at 15ºC DIN 51757 0,842 g/ml
Colour DIN ISO 2049 2.5
Flash Point, CoC DIN ISO 2592 234ºC
Dynamic Viscosity at – 35ºC DIN 51398 5180 mPas
Kinematic Viscosity at 40ºC DIN 51562-1 74.4 mm²/s
Kinematic Viscosity at 100ºC DIN 51562-1 13.2 mm²/s
Viscosity Index DIN ISO 2909 181
And the 0w-30:
Code:
Density at 15 °C DIN 51757 0.843 g/ml
Colour DIN ISO 2049 2.5 ASTM
Flash Point, CoC DIN ISO 2592 234°C
Dynamic Viscosity at - 35°C DIN 51398 5100 mPas
Kinematic Viscosity at 40°C DIN 51562-1 67.6 mm²/s
Kinematic Viscosity at 100°C DIN 51562-1 12.1 mm²/s
Viscosity Index DIN ISO 2909 178
