I have started to wonder if there are some issues being created by the fuel blends many of us have been forced to use , these IMHO foolish, wasteful, even needless gasoline blends , I mean these with ethanol...? I know ethanol wreaked havoc on many small engines we saw n repaired thru my brother in laws small engine repair shop for years. Things that we had not seen much until the introduction of the ethanol. He got to the point he was guilty to charge folks to keep fixing their same issues. So he would try to educate on how to maintain them better. Thru use of ethanol fuel additives , fuel stabilizers and for the winter storage etc... He would even keep additives and stabilizers etc on hand to show them the products they could buy there or other places. He often encouraged them to find and use 100% pure gasoline which is becoming harder and harder to find now. I had to run that fuel thru my last Chevelle small block 400 or it was hell to get it to start. It cranked right up with the 100% pure so it only got ethanol once or twice due to emergency low fuel away from home. Now honestly a lot of those problems - the swollen leaking diphragms , gaskets, plugged and gunked up filters and carbs or plugged up fuel lines etc... are not as much a problem these days for several reasons. Many parts makers realized the issues and started making ethanol safe parts. Things like repair kits for lawn equipment , replacement fuel lines to complete carb kits for muscle cars that have new material gaskets , o rings , diaphragms etc... that can stand up to being in service with fuels that contain ethanol. I wonder if the ethanol fuel affects things differently inside of these direct injection engines to the point there could be a goop, gunk or slime material created and ending up in places like piston ring areas and other spots due to some type of reaction between the ethanol fuel and the oils being used under certain pressures/heat. Maybe it does not even matter what oils we use because the ethanol affects them all the same? Or NOT! Maybe one or more of our chemist , mechanical or industrial engineers or even dealer techs or some race mechainics who see the insides of many engines often can give their insights.
Makes me wonder since some claim most modern day oils to be so advanced and a lot alike. One as good as the other? So how are some still seeing this gunk and in some cases the varnish? Things we do not expect to be found in well maintained engines by the people who do their own proper maintenence by the book? At least the HPL oils and cleaners are clearly being able to remove this from engines to owners surprises when inspecting filters. Can this goop and varnish be some new thing the ethanol fuel is creating regardless what oil a person uses? Or could it be that some of the newer , more advanced oils can maybe not prevent but vastly reduce because this varnish is not found in all engines even though the goop seems to be found more often?
Sorry if this turns out to be like the subject from H___ that keeps turning up , the "Thick vs Thin" one. I missed it if the ethanol questions have been kicked all over the place here already.
