Number_35
That's exactly what the tech who came by today said w.r.t. the advantage of an ECM vs PSC motor.If you run the blower motor all the time, the majority of your energy savings with ECM motors is because they can run at a lower speed for ventilation. So they might only pull 100W at the lower ventilation speed vs the 500W they might pull when running at normal speed. PSC motors are incapable of this, they use about the same amount of power no matter what speed they're running at, and they can't slow down as much as an ECM motor can.
My fresh air ventilation system is on a timer. I currently have it set to run 5 minutes per hour. If outdoor conditions are good (low humidity, mild temperatures), I'll set it to run continuously. If the HVAC system isn't running enough heating or cooling calls for it to run the set amount of ventilation per hour, then it'll turn on the HVAC system fan at low speed (and open the fresh air damper and turn on the fresh air fan to pull air from outside).
We run the HRV 24/7 (although not for the last couple of days, of course) - the house is pretty tight, and the humidity was way too high the first few winters - the tripanes would ice up really badly.
This part of world is bad for radon gas too, and regular air changes help reduce the effects significantly.
