Originally Posted By: CATERHAM
Originally Posted By: 97tbird
What's the VI of GC (Edge w/SPT 0/30)?
EDIT: found it: 167 .... so the VI of 0w/40 is barely above Edge 0w/30...
What does this really mean in terms of real life performance? is it a reason not to use it??
In all honesty, we're splitting hairs here, as is typically the case on BITOG.
I would expect all these LL-01/MB 229.5 approved oils to deliver very comparable performance.
VI of around 170 is very good. Up until recently, only the best of the best had it. Now there are a few oils out there approaching 200. But VI is just one of many of the oil's parameters, not some holy grail. If you're after the highest VI BMW approved oil, then M1 0w-40 is obviously your ticket.
What I personally find intriguing about Castrol 0w-40, as I noted earlier, is its very low pour point, which may point to its high end pedigree, if one is concerned about such a thing. From a practical perspective, does it really matter in some place in North Carolina? I doubt it.
M1 0W-40's higher VI means it's lighter on start-up than both Castrol 0W-40 and even GC 0W-30. How much lighter? It's still 10% lighter at 60F and progressively more so at lower temp's and this is despite M1 having a significantly higher HTHSV.
As for the low poor point, it's a largely meaningless spec' particularly in light of the fact that Castrol doesn't provide very useful MRV and CCS spec's.
On balance once again M1 0W-40 almost impossible to beat for the price and unless Castrol 0W-40 was significantly cheaper I'd stick with M1.
IMO, from my experience in VW CC, once temperature drops below 65, my engine was noisier on start with M1 then it is with GC! With M1 in the morning I always, but always had rattling camshaft sound for about 2-3sec. With GC, that would happen only, but ONLY if I did not drive car for 2-3 days. Rattling sound I did not have with GC one morning in New Mexico when it was 16 degrees.
