Hello - I'll try to give as much information as possible to get the best recommendations.
* 2006 Mitsubishi Evo 9 2.0l turbo
* Factory manual says 10w30 API SL/CF. Factory fill was Mobil 1 10w30 Syn from Mitsubishi
* Amsoil 10w30 used since 300 miles
* Oil changed frequently because I swap turbos almost monthly haha (never sent into Blackstone unfortunately)
* I live in the Pacific Northwest
* 550whp stock block, 30psi
* Uprated cams/valve springs/retainers - 8200rpm rev limit
* E98 fuel (98% ethanol)
* I have no oil pressure #'s to share but the max oil temp I usually see is 90c (~200f) last I recall.
* Has oem oil cooler
* Car has 12k miles and only sees trips to work on Fridays and long freeway pulls during the wee hours making awesome Youtube videos. Trip durations are 1hr - 3hr max. Otherwise it’s a dyno queen.
I ran the factory fill Mobil 1 Syn 10w30 for 300 miles until I switched to Amsoil 10w30. My car now has 12k miles on it and doesn't eat much oil even after going 170 miles to the dyno, making 20 pulls, and driving 170 miles back home. Of course I get some blow-by in the catch can but nothing really disappears on the dipstick.
Should I just stick with Amsoil 10w30? Why change something that’s working? Or should I be looking at Amsoil 10w40 or maybe even the Dominator because of my E98 ethanol setup? Trying to get an extended drain period is not top of my list, neither is trying to save a few bucks, I just want something that helps keep my bearings & stock block happy.
