- Joined
- May 19, 2022
- Messages
- 258
Long time lurker. First time poster.
Things you should know about the car.
2015 Fiesta ST. 141k miles. The car has been tuned since 20k miles. It has whats called a hybrid turbo installed on it for the last 30k miles. It dynod 307whp and 315wtq. I use a mix of 91 and e85 fuels to run E30. And ive been mixing fuels for pretty much the entire life of the car.
I've always used boutique oils on this car. Always used 5w30 (as opposed to 5w20). The car has always been happy. I change oil every 5k. I've mostly used Amsoil Signature and Redline (red bottle) oils. I use either a FL400s or the Amsoil equivalent (depending if I remembered to order one or not). The car is my daily driver (300 miles a week) and my weekend canyon carver.
This car is supposed to suffer from LSPI as it makes 26lbs of boost at 3200 rpm. Ive never had an LSPI incident as I try to avoid the scenarios that can trigger one. But even using Redline (SN rated and high calcium) Ive never had an LSPI incident.
My question is:
Can an off the shelf oil protect this engine as well as a boutique oil? I'm not interested in switching viscosities, the car runs great, and still has perfect compression. Cost isnt the issue.
Should I just keep doing what Im doing? I know a used oil analysis can tell me things but I also know it wont tell me everything
Thank you folks
Adam
My question is:
Thank you folks
Adam
