Ridiculous is right. Absolutely not necessary and overkill...How ridiculous. I’m the type I change it at the exact mileage or sooner I won’t move a vehicle till it gets an oil change if it’s due. If the sticker says a certain mileage I’m not going over it.
Fer sure, the filter had more life left in it!I think that oil had more left in it.
Stock 5.0’s can make 1000 hp with a blower and some basic bolt ons. They are very stout, especially considering you can get one in a <$30k truck.The 5.0 is a durable engine. I know because I raced a Mustang with one. I mean... I put ridiculously expensive oil in it and changed it far too often, but it was modified, went up to 7200 RPM, was constantly rung out, and I even farted on it once. Pretty good.
The dipstick was dry after wiping it?He said the dipstick was dry after wiping it. I'd like to know how much oil is actually left in there. Doesn't sound like he cares to do anything but change it maybe though. We will probably never know...
I would hope so...The dipstick was dry after wiping it?
I feel bad for letting my wife's Crosstrek get to 10K before an oil change. It was the required synthetic oil and a NAPA Platinum filter. The main reason was it was cold and snowy outside. And I thought it was more like 8K miles since last oil change. I do keep the maintenance on a spreadsheet but had not looked at it in awhile.
Until they leave old gasket on the oil filter mounting base, or use wrong oil, or strip or overtighten drain plug or damage something trying to get an air or cabin filter out for an upsell.Quick lube places are everywhere . Sit in the car, sip the coffee they give you, 10 minutes later drive away, warm, cozy, and fresh oil. My grandfather loves those places, so we go together, I drive, because he doesn't like to drive much, and its 12 minutes each way from his house. He sits in the passenger seat and sips coffee, we chat, and 10 minutes later are back on the road. Then we usually go for lunch afterwards. I offered to do it for him many times, but something about them he really enjoys, so we make an afternoon of it. Last time, after the oil change, he wanted lunch at a particular restaurant an 80 minute drive away, so off we went.
I was under the impression the 5.0 Dip stick was 1 qt between the lines? If so, I bet he could have still had 6.5 qts in the thing and not had oil on the stick.He said it didn't register on the dipstick afterwards, is what I meant. So I wonder how much was actually left in there...
Coyote is 1 qt between full and low lines on the dipstick, but in order to be totally off the dipstick it would need to be at least 2 qts low.I was under the impression the 5.0 Dip stick was 1 qt between the lines? If so, I bet he could have still had 6.5 qts in the thing and not had oil on the stick.
This is what he saw when draining the oil. Got about 3 qts of nasty oil out.He said it didn't register on the dipstick afterwards, is what I meant. So I wonder how much was actually left in there...
This somewhat eases my concern over which oil to use in my 5.0
Which would be ~6.5 quarts.Coyote is 1 qt between full and low lines on the dipstick, but in order to be totally off the dipstick it would need to be at least 2 qts low.
