Panda87
I wasn’t very clear from my first post unfortunately. I explained it a few posts in, but sometimes that gets lost in the fray.If there is anything I've learned from my trips to HPL, including the open-house event two years ago, it's that you should NOT mix brands/grades of boutique lubricants.
It is generally very safe to mix most store-bought API licensed fluids for any particular application, mainly because most API licensed fluids don't really stretch the envelope when it comes to additives, etc. It's not like a little more or less of Ca or Mg, etc, is going to upset the apple cart ...
But boutique lubes like Amsoil, RP, RL, and especially HPL are tailored to specific goals and often have very unique chemistry. For example, the anti-foam package in HPL lubes is sensitive to the % ratio of concentration. Further, the lubes may or may not have additives which compete for solubility, etc. Then there's the esters, ANs, etc ... Even ZDDP can be an issue if too much is present. This is like the whole "Goldilocks" topic; too much or too little of a good thing is a bad thing. When you mix products without knowing the EXACT additive package in both, and how they will interact with each other, you have no idea of what effects you may be creating.
Amsoil makes great products. HPL makes great products. But without knowing the potential for chemical coercions pro and con, I'd advise to stay away from mixing them.
What you can do, and what you should do, are two different things.
The oil I pulled was purely Ams SG 75w-140.
The oil that went in was all Ams SG of various grades (3.5 pints) because I wanted a carrier oil for the HPL Diff Life Cleaner (the only non-Ams oil added at .9 pints)
Do you think the small amount of the HPL diff life cleaner would affect the fluid that adversely? Before I jumped into this little experiment, I noted that the page for diff life cleaner specifically stated “Compatible with other conventional and synthetic gear oils” so I assumed it was suitable to mix with the Amsoil SG I had remaining, but I’m no tribologist or expert.
