Hello again,
I ordered 6 quarts of HPL 75w-140 and a quart of HPL’s Differential Cleaner. I’m two weeks post shoulder surgery, spending too much time on the internet reading BITOG and buying HPL, lol.
I decided to drive around for a while then crawl under my ‘14 Navigator, crack the fill plug, pump out .45-.5qts of diff fluid and pump in the same volume of the HPL differential cleaner. As soon as I cracked the fill plug off, some lube started pouring out. The color of the lube was grayish when running thin against the diff housing and I thought “hmm, wonder if water got in?” so I drained the whole diff. I took a photo of what came out.
This was AMSOIL Severe Gear 75w-140 for ~20,000 miles, 5000 of which were towing a 7500lb camper. The differential fluid had likely never been changed prior to me draining it and filling with the SG, so I assume the SG picked a lot of the previous muck up from the old gear oil and held it in suspension. It was far darker than I expected and stunk like radioactive roadkill. My sons were playing outside and I heard one of them go “EWWW WHAT IS THAT SMELL!?” and made a vomiting sound.
I filled the diff with .5qts of HPL Diff cleaner, 1qt SG 75w-140, 1/2qt SG 75w-90 and 1qt of SG 80w-90. It was all leftovers from other changes and since it wasn’t going to be in there terribly long, I wasn’t worried about not going the full 75w-140. I’m at 163,500mi now on the Navigator and will likely run this to 170k, drain and refill with HPL 75w-140.
I’m not sure what to think of just how gnarly this fluid looks with only 20,000 on it. Maybe towing beat it up? Maybe it’s cleaned out remnants of the factory fill that was in for the first 140,000mi?
What are y’all’s thoughts?
When I drain the Diff Cleaner and other fluids out at 170,000, I’ll take pics and add them to this post. Edit: I meant to add, there wasn’t an unusually different than normal amount of black paste on either the drain or fill plug magnets.
