- Joined
- Sep 18, 2025
- Messages
- 2
I ordered a case of Mobil 1 75w-140 GL-5 gear oil for use in the rear axle of our '04 diesel pusher (Freightliner XC chassis) motorhome. The mechanic filled the diff before noticing that the oil is labeled Light Truck & SUV. The Amazon listing did not have that info, unless you enlarge the photo of the product enough to read the label.
The axle specs call for 75 or 80w-90 or 140 weight. Most of the time we are pulling about 8500 lbs with our 25,000 lb rv, which is comfortably below the GVWR. The weight we tow pushed me towards a 140 gear oil.
I hate to dump $100 worth of oil, but it seems the only option unless 140w light truck would provide the same level of protection as a 90w heavy truck oil.
We live in a rural area, and I'm having a hard time finding a name brand 75, 80 or 85w-140 Full Synthetic gear oil from the usual good value online sources (Amazon, Walmart, etc). I need 7 quarts, so buying a pail is out of the question.
Amazon offers Valvoline Advanced Full Synthetic 75w-140 that is GL-5 and SAE J2360, but the Meritor list of approved oils lists Valvoline HD Full Synthetic with EP.
Any suggestions as far as an online source of heavy truck gear oils?
