How is moisture getting in the oil to begin with? Is the PCV system letting it in?
Condensation
This thing made a liar of me. It touched 220* today on the highway. I don’t ever remember this but it’s not even hot out yet. My memory must be shot.I was running errands around town yesterday. If I was in traffic, mine went as high as 224F.
From? Combustion blowby as noted plus modern PCV puts air from the upstream intake into a valve cover and pulls it out of the other valve cover into the intake valves. Does that leave moisture in the crankcase?Condensation
bingo we got a winner here. Nice write up.I think something many people misunderstand is how "moisture" can move from phase state to phase state.
As we all know, ice is frozen water; that happens (assuming "pure" water) at 32F.
Water exists between 32F and 212F (at sea level; less at higher elevations).
Steam exists above that boiling point of 212F.
HOWEVER ...
Moisture will evaporate at well below the boiling point. An oil does NOT have to be at/above your boiling point to rid itself of moisture. The rate of evaporation is dependent upon two things:
- relative humidity level in the immediate atmosphere; the greater the disparity the quicker the evaporation
- relative surface temperature where evaporation occurs; the greater the temp delta the quicker the evaporation
The boiling point is the temperature (depending upon system barometric pressure) at which you can force a phase state change for all the mass, given enough time. But we can still rid the liquid of moisture by having temps which induce evaporation. If evaporation didn't work below the boiling point, then human sweating would pretty much be a fruitless venture ...
Moisture will leave the engine oil via evaporation, it just does it quicker when the oil exceeds the atmospheric boiling point.
HOWEVER ...
The beauty of coolant/oil heat exchangers:Interesting.
Makes the whole "drive it once in a while to burn off the water" a bit of a farce. My truck never sees 220* oil temps (if the sensor is close to accurate). 212-215* max, iirc. I have seen the Pacifica touch 220* but not often.
Overkill, I have a 2016 Ram 3500/w Cummins. it has a oil temp and pressure display. But the interesting thing is those temps on the gages are calculated, not actual.
I was actually over this with somebody before Also, I have access to an actual Mopar WiTech pod, which gives access to everything, including the ability to perform updates.Overkill, I have a 2016 Ram 3500/w Cummins. it has a oil temp and pressure display. But the interesting thing is those temps on the gages are calculated, not actual.
If I take my scanner, connect to the OBD2 port I have access to about 320 engine parameters, but the only reading regarding oil values is Oil Press Switch state open or closed. In other words, it has oil pressure or it doesn't. I've looked all over that engine and it only has one 2 wired oil pressure switch in the main oil rifle. I'm pretty sure the Hemi is the same way..
cool... as far as I can tell the Cummins models don't have a real oil press or temp sensor.. just a switch.. did not know that about the Hemi, but its a good thing.. I know mine is a liar... Give you a perfect example, you can be driving and the oil temp reading migh tbe 200 or so, but descend a large hill with the engine brake on and see the oil temp drop suddenly by 40 degrees.. logic decrees liquid temperatures dont change in an exponential manner in seconds.I was actually over this with somebody before Also, I have access to an actual Mopar WiTech pod, which gives access to everything, including the ability to perform updates.
I'm not surprised the Cummins-equipped trucks "fake it" for some of the parameters.
The HEMI does in fact have real oil pressure sensors and oil temperature sensors, it's integral to the MDS system, that's how it determines if you've significantly deviated from spec visc or not, as it infers viscosity from oil temperature and pressure.
- The pressure sensor is a 3-wire unit on the front of the engine at the top of the timing cover, part #68334877AA
- The temperature sensor is above the oil cooler (on vehicles so equipped), per this diagram posted by The Critic:
Apparently, if you had a HEMI, it would be part #5149077AB, but I'm not seeing one listed for the Cummins, so I suspect your suspicion is bang-on.cool... as far as I can tell the Cummins models don't have a real oil press or temp sensor.. just a switch.. did not know that about the Hemi, but its a good thing.. I know mine is a liar... Give you a perfect example, you can be driving and the oil temp reading migh tbe 200 or so, but descend a large hill with the engine brake on and see the oil temp drop suddenly by 40 degrees.. logic decrees liquid temperatures dont change in an exponential manner in seconds.
yeah, I have the actual Cummins part book,instead of the OEM parts list and it just lists a switch.. so that is how Cummins Inc sent engine to Mopar for final assembly. I used to have access to Cummins Quickserve, used engine serial number and CPL # to print myself a parts book for the engine.. beauty of Cummins is even thought they ship the engine to Mopar and Mopar warrants the stuff, you can buy parts direct at any authorized Cummins Distributor. all you need to know is the serial number of the engine and you save some money, mopar marking the parts up from Cumminsprices.Apparently, if you had a HEMI, it would be part #5149077AB, but I'm not seeing one listed for the Cummins, so I suspect your suspicion is bang-on.
In order for any water vapor trapped inside the engine to condense, the dew-point of the water vapor relative humidity would have to be obtained for the inside of the engine to "sweat". Modern engines are essentially sealed from the ATM when shut-off due to a properly working PCV system, so it would be basically impossible for outside water vapor to ingress into an shut-off engine. However, the PCV system does pull ATM air through the engine to evacuate the sump, so in hot and humid environments, at shut-down the engine will be filled with more water vapor in a high humidity area vs a low humidity area.Condensation also introduces water to the oil as the difference in temperature inside and outside of the crankcase causes the block to "sweat" and thus moisture enters the crankcase and the oil.
Moisture leaves the engine via the PCV system.I think something many people misunderstand is how "moisture" can move from phase state to phase state.
HOWEVER ...
