YesIs that the 3.6L Pentastar?
Took the city/suburban route today commuting to and from the office so here are the oil temps from today. Starting oil temp was 5F and the ending oil temp when I got to the office was 158F after a little over an hour of driving and it took ~40 mins for the oil to get to 150F. On my way home, the oil temp when I was pulling into my driveway was 165F with the outside temp in the mid twenties.What is oil temperature in the city?
Everything is working as designed as far as I can see, so I don't see a point in asking a dealership about it.If OP confirms with Mazda this temp is normal I would not give it another thought.
IMO, that is a problem.Took the city/suburban route today commuting to and from the office so here are the oil temps from today. Starting oil temp was 5F and the ending oil temp when I got to the office was 158F after a little over an hour of driving and it took ~40 mins for the oil to get to 150F. On my way home, the oil temp when I was pulling into my driveway was 165F with the outside temp in the mid twenties.
The coolant temp once it warmed up was 170-180F, depending on if I was going down a hill or not. So the coolant temp is with in the normal range for the stock 180F thermostat. Running the heat sucks a lot of heat out of the coolant when its 10F outside. Then with the quantity of oil (almost 6qt of oil for a dry engine) that the N/A Skyactiv engine takes and no coolant to oil heat exchanger, the oil temps I'm seeing don't seem too far off from what I would anticipate.IMO, that is a problem.
WHat is your coolant temperature? I was looking on at Rock Auto, Aisin thermostat for CX-50 is 190f.
What are changes going downhill?The coolant temp once it warmed up was 170-180F, depending on if I was going down a hill or not. So the coolant temp is with in the normal range for the stock 180F thermostat. Running the heat sucks a lot of heat out of the coolant when its 10F outside. Then with the quantity of oil (almost 6qt of oil for a dry engine) that the N/A Skyactiv engine takes and no coolant to oil heat exchanger, the oil temps I'm seeing don't seem too far off from what I would anticipate.
The thermostat probably can't react quick enough to prevent the initial coolant temp drop when starting to coast down hill, it always comes back up quickly though. So I doubt its faulty thermostat.What are changes going downhill?
I see that, it definitely acts like a 180f thermostat, if you look at older Skyactiv engines with a true thermostat, they are rated for 180f.Also, on Rock Auto thermostat is 190f. I wonder if you have some kind of "hot climate" package? Though that usually includes different equipment.
It is most definitely a design decision by Mazda, but I have a feeling its not a direct design decision regarding temperature. Where as on your BMW, they could have made specific engine design decisions to better manage oil thermals.I mean, my BMW is also naturally aspirated with 7.3qt oil sump, manual (so less load) and oil temperature in city driving after 15-20min is around 220f at those low temperatures. No heat exchanger, but there is a radiator-type oil cooler with a thermostat at 230f. On the open road, I need 10 min, maybe at 10f temperature, to reach 220f cruising, maybe at 75mph.
It could be by design. IMO, if that is the case, they mitigated another issue with such a design. A larger oil sump could be for OCI's.
In today's day and age of CAFE everything, running higher temperatures is the most basic trick to be CAFE compliant and boost mog, not only bcs. EPA but also bcs. marketing.
Perhaps. BMW definitely has a more complex cooling system with an electric water pump, different mods of operation, etc. But, warming up is, warming up. My Toyota Sequoia warms up oil in a similar manner, too. BMW also has underbelly protection, so it retains heat. Does Mazda has?It is most definitely a design decision by Mazda, but I have a feeling its not a direct design decision regarding temperature. Where as on your BMW, they could have made specific engine design decisions to better manage oil thermals.
Just spit balling, Mazda could have routed the oil passages further away from the coolant passages than in typical engine design and/or the oil passages are closer to the outside of engine block/head and more exposed to airflow through the engine bay. It could also be something like the oil sump sitting lower in comparison to the rest of the engine so its further away from the heat source.
I was looking around at thermostats and I'm not convinced that the Aisin on Rockauto has the OE temp spec right. I'm thinking it may be the thermostat for the Turbo engine not the N/A engine. The coolant gets to temp reasonable quick when the heater isn't running and is acting similar to my previous car, a 2010 Chevy Malibu, in regards to coolant temp fluctuations while driving, so I doubt its the thermostat. When the thermostat failed on my Malibu, the coolant temp never went above ~160F even in the middle of summer before I got a chance to replace it.IDK, Aisin is a reputable company; heck, the OE thermostat might be Aisin. I would say it is a 190f thermostat, and you might have a failing thermostat. I was looking at part numbers; it is definitely different from CX-5, and it is cheap. I would start there.
I understand, but that is weird. Manufacturers are fighting for every drop of fuel. They introduce 0W8 oils just to be CAFE compliant. Bumping oil temperature is the easiest way to bump mpg. If so, well, who knows a reason.
I would start with the thermostat here. I think it is failing.
