The issue is water accumulating faster than it can evaporate out. The clothes on the clothesline aren't being sprayed with mists of water as they're trying to dry.
Condensation isn't the only source of water in the oil as it also comes from the fuel as a by-product of combustion. Burning 1 gallon gasoline produces 1.033 gallons of water, some of which inevitably ends up seeping past the rings and into the oil. In areas with high humidity, you also pull moisture in by way of the PCV system.
The oil is near constantly being hit with water from multiple sources so you want to keep the oil hot enough that water vapor in the crankcase remains a vapor, and liquid water in the oil can quickly turn to vapor, and all get vented out of the crankcase faster than it is accumulating.
There is an extraordinarily captivating article available that explores the peculiar segregation of TBN additives, polymers, by water (blow by) precisely in the region surrounding piston rings. This exceptional phenomenon arises from the specific composition of the mixture, which includes both PAO and lavish esters.
https://doi.org/10.1016/S0167-8922(03)80166-9 (
https://www.sciencedirect.com/science/article/abs/pii/S0167892203801669 )
illuminating excerpts sourced from this article -
The solids deposition, the chemical tests for Base Number and additive presence and also the physical measurement of viscosity indicate that it is the additive package which is separating out from the base oil under the initial conditions in the ring zone.
The implications for short journey, cold start conditions are that, for at least the first hour, the ring groove temperatures require a considerable time to equilibrate at what is normally regarded as 'operating' temperatures. The loss of additives appear to give reduced lubricant performance protection properties for the degraded lubricants under these conditions, compared to the fresh lubricant. "
Separation and analysis of the solid phase shows it to be predominantly polymer from the viscosity index improver with traces of other additives present, such as Base Number and anti- oxidant.
The ring zone sample mass varies with time, Fig 3, decreasing sharply with the progress of the test run from 6-9g/hr at 15min, decreasing to -2-3 g/hr
at 60 minutes, according to the base oil formulation.
The interesting point for these samples is that after one hour engine operation the extent of physical degradation gradually declines with time,
the samples eventually becoming 'normally degraded', defined as being substantially changed by exposure to the conditions in the ring pack zone but as a homogenous phase."
