Originally Posted By: volk06
Originally Posted By: GumbyJarvis
Kendall, Motorcraft, TropArtic are all 3 COP Oils that all 3 have a great reputation.
MC is easiest to find around here, its really close to TropArtic formula.
I'd use Motorcraft or TropArtic with confidence, Kendall, not so much, personal reasons aside, all 3 have good reps.
Just curious about why you say that about kendall?
Past reasons, mostly a botched job by my mothers mechanic that made me start doing my own oil changes,
the stuff burned wicked bad in my engine, IDK why.
it was Bulk 10w30 Kendall Dino.
Ive run synthetics and dinos in my truck since, ranging from 0w20-10w30 and everything in between, High Mileage oils, HDEOs, and nothing has burned from them,
It was paired with a NAPA gold, and a NAPA A/F at the time as this shop is a NAPA Autocare Center.
My truck likens Kendall to Pepsi I guess, idk.
liked it enough to consume 1 qt every 500 miles though.
since then I have had no burning, though I learned my valve seal gasket is going now, so yeah
Off the record, after 1000 miles I changed it, and had to hammer a smaller socket on the stripped drain pan bolt to get it off
and I had to pop the oil filter with a screwdriver.
