I've always heard that most of your braking is provided by the front wheels. Is there some generally accepted figure for this? I realize there are plenty of variables ...
I remember for my 85 Dodge Omni the published value was 80% of the braking was done by the front brakes.
My rears wore out on my Mada6 before the fronts. It was the first vehicle I owned where that happened, and it is also the first one I owned with stability control.Was true back in the day but with modern stability control and ABS systems the rears do a lot of the heavy lifting. I want to say pretty much every car I have purchased in the last 15 years or so (about 5-6 including my wife) the rear pads wear before the fronts or at least the same. I just did the rears on her Forester at 55k, they had maybe 10-15% left and the front still has about half.
My 2007 Corolla was still on the original rear shoes when I sold it at 180k miles. Every year or so I would pop off the rear drums and look at the shoes, then just put the drum back on. I sold it with the set of replacement shoes I bought but never installed.Same thing with my DD '86 Daytona. Over the past decade I've done the fronts twice and only changed the rear shoes and hardware due to age and personal boredom when changing a leaky wheel cylinder. Sometimes I think the rear setup is only there for the parking brake.
My ‘07 Corolla needed rear shoes because the brake shoe linings were falling off due to rust! What was left wasn’t worn much!My 2007 Corolla was still on the original rear shoes when I sold it at 180k miles. Every year or so I would pop off the rear drums and look at the shoes, then just put the drum back on. I sold it with the set of replacement shoes I bought but never installed.
In a maximum stop, the fronts do 80-90% but I guess with electronic brake distribution the rears could be setup to do more?I've always heard that most of your braking is provided by the front wheels. Is there some generally accepted figure for this? I realize there are plenty of variables ...
It depends on the rate of braking and the height of the center of mass because that determines weight transfer.I've always heard that most of your braking is provided by the front wheels. Is there some generally accepted figure for this? I realize there are plenty of variables ...
I have similar experience with my Jeep Patriot. The front pads last about twice as long as the rear shoes. I'm not sure if it's front/rear bias or differences in material and caliper vs. drums.Was true back in the day but with modern stability control and ABS systems the rears do a lot of the heavy lifting. I want to say pretty much every car I have purchased in the last 15 years or so (about 5-6 including my wife) the rear pads wear before the fronts or at least the same. I just did the rears on her Forester at 55k, they had maybe 10-15% left and the front still has about half.
I've seen this on a '19 GMC Canyon, too.The fullsize Transit vans have HEAVY rear bias over the fronts-I’ve gone through 2 sets of rear pads before the fronts wore out. Guessing Ford assumed a lot of weight over the rear? Many years ago, when I was young, the company I worked for had overloaded S-10s as service vehicles, with basically useless rear drum brakes… Talk about a handful in a snow or ice storm!!
It's not just that they assume a heavy weight bias to the rear, but they often cheap out on any means of brake bias adjustment.The fullsize Transit vans have HEAVY rear bias over the fronts-I’ve gone through 2 sets of rear pads before the fronts wore out. Guessing Ford assumed a lot of weight over the rear? Many years ago, when I was young, the company I worked for had overloaded S-10s as service vehicles, with basically useless rear drum brakes… Talk about a handful in a snow or ice storm!!
Honda (on some Acura models) and Mazda now use rear brakes to help induce yaw and "improve handling."20+ years ago the OEM's discovered that reducing front dive on braking = luxury feel for soft sprung sedans. Then when multi function ABS came popular, then the rear bias for braking became, lets apply the rear brakes to augment the steering wheel, and control handling.
Those rear brakes get far more use now.
