- Joined
- May 16, 2022
- Messages
- 865
I always thought the front did all the stopping until the wives VW needed rear brakes FIRST!
VW told me the rear brakes stop first now...
Bingo. "Trail braking" by having the rears doing more work under light application has become a thing.20+ years ago the OEM's discovered that reducing front dive on braking = luxury feel for soft sprung sedans. Then when multi function ABS came popular, then the rear bias for braking became, lets apply the rear brakes to augment the steering wheel, and control handling.
Those rear brakes get far more use now.
I just did the brakes on our cx-5 this past weekend , at 49k miles.Was true back in the day but with modern stability control and ABS systems the rears do a lot of the heavy lifting. I want to say pretty much every car I have purchased in the last 15 years or so (about 5-6 including my wife) the rear pads wear before the fronts or at least the same. I just did the rears on her Forester at 55k, they had maybe 10-15% left and the front still has about half.
I've seen this on a '19 GMC Canyon, too.
I just did a '19 Rogue with 140,160 miles. I had done the rears a couple years ago, but the original front pads absolutely could have gone longer -- the thinnest was about 4mm. The owner was paranoid and basically insisted on doing the fronts now.
I try to maintain objectivity and be mindful of customers' budgets as well the appearance of a conflict of interest, ie I'm recommending things which make me money.I would have also replaced the front brakes.
Beat me to it - without ABS, physics takes over, so yes, the front brakes will do most of the work.Its purely physics about having front brake bias. Moving forward, a vehicle will transfer more weight to the front when braking than the rear
Physics takes over under hard braking with or without ABS, in that nose-down pitch will transfer weight to the front tires. As others have mentioned, that de-weights the rears, reducing usable braking force back there. The system(s) may decide to modulate braking force delivered to the front wheels to keep the tires rolling and therefore maintain steering capability.Beat me to it - without ABS, physics takes over, so yes, the front brakes will do most of the work.
Look at the size of the front brakes vs rear brakes too. The fronts are always larger, sometimes substantially, and even with ABS, traction control, and so on, automakers haven't changed this much. It does explain why - as many in this thread have commented - rear brakes wear out as fast as the fronts or even before. It's not that they're doing a lot more work than the fronts either, they're doing more proportionally but are smaller to start with.
I know. I always figured that GM, Ford and Chrysller saved a few dollars 70 years because drums were chaper than discs. .Drums aren't the solution, though (not that I mind drums). GMT900s with drums still bias to the rear and the shoes wear down surprisingly quickly
Yeah, they must be cheaper?I know. I always figured that GM, Ford and Chrysller saved a few dollars 70 years because drums were chaper than discs. .
