Moly in Rotella?
Kansas City Metro
Does the new CJ-4 Rotella in 5w40 contain molybdenum? Anyone have a VOA for this oil? I want to run it in my bike but I wanna make sure it will not screw up my clutch.
There's a UOA about halfway down page 2 of this thread:
https://bobistheoilguy.com/forums/posts/1485632/
Moly looks like its about twice the old (CI) formula, but still only 40 PPM. I don't know if that's enough to cause problems in a bike clutch or not.
I'm pretty sure the 15w40 conventional doesn't have any moly. I've been running it the past few cycles, and my latest UOA has a moly count of 3ppm (see here).
(Note: moly numbers early in my UOA cycles were due to what was applied at the factory. They've been declining ever since.)
I can't speak directly to the 5W-40 synthetic. It may well be that they have a *slightly* different formulation for the synthetic.
But in any case, I think Delo is the only HDEO that has moly numbers up in the triple-digit range. If Rotella (or Delvac) do, it's down in the double-digit range, maybe even lower.
And based on everything I've read, that much won't affect the clutch.
The soluble moly in modern oils is a non-issue regarding wet clutches. The "no-moly" comes from older oils that had MoS2, like the ARCO Graphite stuff.
