quote:
Cam someone elaborate on the wear limits allowed by API SM?
- average cam plus lifter wear: max 60 microns
Sequence IIIG test as noted above. Note: this includes breakin wear.
- cam wear average: max 90 microns
Sequence IVA Test.
This test measures scuffing wear, which is wear that occurs during the break-in period of the engine. That is, no special lubricant/grease aids cam breakin on a 1994 Nissan KA24E 2.4-liter, overhead camshaft, non-roller finger followers.
7 points on the cam lobe nose, between 14° before and 14° after max lift, are measured and
ADDED TOGETHER, and then the average is taken for all cam lobes.
- bearing weight loss: max 26 milligrams
Sequence VIII Test.
This test's main purpose is to test for bearing corrosion under high-temperature operating conditions using unleaded fuel. It also measures measure viscous shear stability under high-temperature operating conditions using unleaded fuel, but the test rig is a 42.5 C.I.D. carbureted, single-cylinder, spark ignition, with an external oil heater circuit, that most consider obsolete. This test will most likely be replaced by a bench test for GF-5.
[ February 28, 2006, 06:58 AM: Message edited by: 427Z06 ]
