MolaKule:
But 99% of all base oils and additives are shipped in liquid form.
Except of course those that are shipped in other forms, such as granular, which are then mixed with a solvent, as is trimethylolethane apparently is. That doesn't sound like a great base for a motor oil but it does sound like a great additive to "paints, powder coating resins, polyol ester synthetic lubricants, plasticizers, stabilizers for plastics, and titanium dioxide pigment coatings" in which you could dissolve it.
Now, that isn't quite as spiffy a statement as:
"Polyols are made by reacting multifuntional alcohols with a monofunctional acid....They are, however, much more stable than diesters, and tend to be used instead of diesters where temperature stability is important. A general rule of thumb is that a polyol is thoguht to be 40-50 C more thermally stable than a diester of the same viscosity. Esters give much more lower coefficients of friction values than those of both PAO and mineral oil. In general, polyol esters based on TMP or or PE give lower values [of friction] than diesters."
"For those just tuning in, there are three major polyol esters: pentaerythritol esters, di-pentaerythritol esters, Tri, Qantinary-pentaerythritol esters, Trimethyl Propane esters (TMP), and Neopentylglycol esters (NPE). A fairly new one is the TME ester discussed earlier. All are very hydrolitically, thermally, and elastomerically stable."
but it is probably more germane to the discussion, in "laymens (sic) terms", or even in laymen's terms.
I understand from a chemist friend in Fairfax, Virginia, that one of the major makers of synthetic lubricants uses trimethylolethane as an *additive* in a number of products - the exact chemical make-up of which and the history of I'm sure you'll be happy to regal us with.
I'm betting it has something to do with enhancing performance in high temperatures, resisting hydrolysis, retarding oxidation, and as a friction modifier.
But I'm no physicist.
