First, would I ask our moderators to delete my previous message since it was already posted by Buster ? TIA.
As for results themselves:
- the weight loss is in grams
- metal plates represent engine metallurgie (think similar to those used for Antifreeze testing)
- duration is 3 and 5 hours (not one hour)
Indeed, the authors have not indicated the test method, just specified it was "high temperature oxidation test". As I know it's quite usual test method to check properties in the lab. All magazines tests are made either in the lab of the Ministry of Defense or in the Moscow Research Insitute of Lubricants. We don't have private labs. I don't believe people working there are stupid to use something really unscientific and then to publish it. According to the magazine all oils were fully OK in respect of declared performance, but, as you understand, OK close to the high end and OK close to the low end of some property is not the same, otherwise it would sound like an average temperature of patients in the hospital. For us, readers, results may serve an indicator of some weaker sides that, at certain conditions, may be critical. By the way, these results are quite in line with those made in Australia and published by Exclusive Motosports, Melburn. The same weak points: oxidation, corrosion, chemical compatibility.
In addition, a few words about correct citing. Believe when saying about a higher corrosivity of esters vs PAO or mainly formulated with PAO, it was clear that this concerned PAO oils: 0W-40 from Shell, Mobil and Castrol, as well as conditionally considered as PAO: 5W-40 Liqui-Moly and Chevron Delo, but not all listed oils. And sorry, but I don't think 10 g with Chevron and 16-17 g with Motul are equal. May be in areas with mild climate where there is a high quality gas they will be equal, but given the bias I would bring some changes in oil intervals or change the brand itself.
