Mobil Super HTHS
Roseville, CA
I e-mailed Mobil asking them to provide the HTHS values at 150C for the Mobil Super and Mobil Super HM lines since they're not in their respective PDS's.
They e-mailed me back: "No I apologize we cannot, as these values are not available for these products.".
Looks like the Super and Super HM 10w40 are going to be the only ones with ht/hs above 3.5 cP. Everything else is going to be below that since it meets ILSAC GF5.
Hoping but not expecting
Originally Posted By: ARCOgraphite
Are you expecting or hoping that the HM has a higher nominal HTHS than the SAE/ILSAC spec range?
It's exactly the 10w40 that I'm interested in.
I'm not convinced that not meeting ILSAC GF5 means a higher HTHS. Looking at the Castrol GTX, the 10w40 has a HTHS of 2.9 just like the 5w30 and 10w30.
No it doesn't. Castrol is just not very forthcoming on specs, it indicates it meets the minimum requirement of 2.9 but does not list the actual HTHS. That's what the < means. If you look at the kv@100 viscosity spread it is quite clear the Castrol is plenty thick, knowing Castrol the HTHS is likely around 3.7 to 3.9.
Why they just don't publish I don't know. A few of their newer lubes actually list HTHS now though.
Thanks Quattro Pete and KCJeep! .
Yep, those two are gold and always worth listeng to.
