But while here ,
Mobil Drive Clean High Mileage Synthetic Blend :
I don't suppose they use ------------- ?
The spec is a very clearly headed:quote:
Originally posted by dustyjoe1:
Great, I guess I know what to do with my daily dose of vitamin E. What is the significance of the 1% antiox additive. I'm afraid the implications of your statement evades me. Clarification please.![]()
FWIW - I have a good friend who's a chemist, but not familiar with oil formulations. I mentioned this thread to him and the first thing he asked was "Are they using it ( alkylated naphthalene ) as a surfactant?"quote:
Originally posted by Motorbike:
Just a thought though as it's doubtfull . I think surfactants do that job in part .
Mobil 1 SuperSyn uses the AN's and they are for sale to other blenders but who uses them currently ? Not a clue .
Typically, one would obtain a 1 to 5-gal. sample along a "Certificate of Analysis" (COA) which would show most of the details.quote:
The kind of people who would consider buying this product would be obtaining samples, pricing, and technical data such as production variability and additive compatibility, so they wouldn't be relying on the specs on the website for decision-making.
I'm wondering the same thing or even if its in the Mobil 1 SuperSyn. Sounds like a very impressive base. Aren't ya glad I posted it?quote:
Are you guys using this groovy base oil in the Mobil Synthetic Blend and if so , does it help clean ?
But with his background he might could help us along ? He already knew something about it .quote:
quote:
Originally posted by MolaKule:
My point was that even with technical specs, you have to troll through the specs with a fine-toothed comb and cut through the hype at this level as well.And my point was that the insinuation it was hype didn't jibe with either the plain English header of the specification, the clear footnote, nor the market to which the information was directed.
Apparently they are not pushing this as a base stock but a blend stock, and in that use - a fully formulated motor oil - an AO would usually be incorporated.
I'm with you. I'm going to try to get him to reg. He works with solid rocket fuels plus coatings and adhesives but knows plenty about a variety of things chemical. He's the one of the guys that first convinced me to try Mobil 1 in fact. I'll see what I can do...quote:
Think he might could join in the discussion with us ? The more , the merrier![]()
I only found 5 hits when searching through all the forums for AN's. Sounds like they are very valuable to a formulator and I wouldn't be surprised if a small amount is present in Mobil 1 SuperSyn. The M1 descriptions lists Mobil 1 as being Synthetic base fluids including Pao. So could be esters but I'd be willing to bet it's AN. Could this be the "ester less" part of M1? Are these AN's even really classified as Esters? Maybe George Morrison knows.quote:
That would be a good topic since Alkylated Naphthalenes and benzenes are set to possibly replace expensive esters. More testing will show if they will really do this.
quote:
Originally posted by tdi-rick:
You've all been talking about M1, but what about their HDEO's up to and including D1 ? (D1=26% Group V, it's surmised)
It sounds like it would suit this application perfectly.![]()
Rick.
Not quite correct, Mobil's AN is an olefinic AN and the additive solubility for the higher viscosity AN is pretty poor as of now. They only have two major AN's for PCMO's.quote:
[Comment from Geoff William: The first component (alkylated naphthalene) has the advantage over PAO and esters in that it has the best additive solubility and the best seal compatibility of the 5 most common engine lubricants (PAO, esters (2 types) and mineral oil)."
Group V fluids are esters, AN's, AB's, etc. Anything not conforming to Group I-IV are placed in the Group V category.quote:
So PAO has it's own group. I would guess that someday (if things get too crowded in the V group) they will have to split out a Group VI, leaving esters with it's own group.quote:
