quote:
'Kule: "Some have said that esters have moisture attracting problems, but have never documented that is the case with modern esters. I think what we have here is a case of some people posting old data."
blano and Cujet in two-stroke oil threads in the small engine subforum have claimed serious water absorption and corrosion problems with Red Line's racing 2-stroke oils.
I don't disagree with Blano and Cujet and respect them highly. I believe they may have observed corrosion, etc, but what was the root cause?
But here are some questions to consider:
Was the fuel/oil mix tested for water content after it sat in the tank, and if so, was it the esters or the rest of the formulated package that attracted moisture? Did moisture settle in the mix due to tank condensation?
In my view, for this specific case, the question here is not that corrosion was caused by the base oil esters, but the problem may be with the additives and solvents.
All fully synthetic 2-cycle oils (including Mobil's MX2T) contain three major components:
A. Approx. 75% mix of POE and diesters,
B. Approx. 17% Additives such as AW, RI's, and detergents, combustion enhances, emulsifiers, etc.
C. Solvents: 8%
The problem here in my experience is not with Item A, the majority base oil, but with Items B. and C. In other words, additives and solvents can cause corrosion if not in the proper ratios or if they are absent. We know that certain additives don't play well together. If one of the additives attracts moisture during combustion (such as a combustion enhancer), then the cylinders and CC could be blasted with a corrosive mix of spray. Then after the engine cools down and condenses water vapor, parts rust.
What needs to be determined in this case is whether or we have rust due to condensation, or is the corrosion caused during combustion, for example, does the additive package actually contribute to some type of acidic reaction?
I usually find there are more than one cause for any effect.
Just some food for thought.
