Originally Posted By: priler
i agree with everyone else here,no need to change what your doing.a short trip to maintain because it sat for only two weeks,would be worst.
one thing i would recommend however,is to maintain the battery.
i'm not too familiar with your vehicle,but many have computers,clocks,etc.,that draw tiny amounts from the battery.one of the things that kills a battery before it's time,is keeping it at low charge and it makes the charging system work more.
i'd recommend a battery tender that self monitors(not a simple trickle charger wich may damage the battery).there are many brands out there.when the battery is fully charged,it goes into maintenance mode.
many of them have convenient connections you can hook up to the battery terminals(permanently) and place the end piece in a out of the way,but accessible spot.you then just run an extension cord and connect.(no need to take out the battery)
i have both my aprilia and porsche this way with no problems from sitting for long periods and then suddenly get used HARD.my aprilia in particular has a sophisticated computer/dash that will most definitely kill a brand new battery in a comparatively short time.
two weeks isn't that long but depending on the systems in your vehicle,it may be pretty long for the battery.
+1 My R1 and my Ninja both sit with a battery tender on them all winter, I run the "pigtail" under the rear seat. works flawless. And although i dont have a dedicated system for my Silverado, if it sits for more than a few weeks, i pop the hood and throw the trickle charger on it for a bit, just to bring it back all the way up.
