Hallo all,
I have a mercedes e220 cdi (OM 646 LA engine ).
acea uses This verry engine for wear control test for all acea ratings:
http://www.aftonchemical.com/Lists/Brochure/Attachments/40/Afton_Lube_Spec_Handbook_2012.pdf
page 81 I believe.
the thing is wear limits on the components of this engine are the same for a3/b3 and a1/b1.
So if I switch over this engine to mobil 0w20 (rated a1/b1).
The engine must be fine, because it is tested using this oil, and must not wear any faster then a3/b3 oil.
I am thinking about switching over towmorrow.
What are your thoughts
page 81 I believe.
