It doesn't need one. The filter mounts vertically and oil doesn't drain UP.i noticed that the OEM skyactiv original oil filters don't have a anti drain back valve, for what reason?
Oil in the galleries above the filter can still drain down if there's no ADBV.It doesn't need one. The filter mounts vertically and oil doesn't drain UP.
It would also indicate an attempt to band-aid a design defect. Good luck with that, no one else has pulled it off.I say that because if Mazda "requires" use of a certain filter only, i.e., the "high flow" OF, then Mazda has to pay for it. That's part of the Magnuson Moss Warranty Act. Guaranteed Mazda not paying for an oil filter for anyone.
Personally, count 'me' as skeptical about the "high flow" oil filter. 'To me' reads like something to get owners to buy the specific Mazda OEM oil filter only. My.02
so I got the Beck Arnley filter in the mail from RA and immediately can see the black ADBV. Not a deal breaker for a cheap filter was hoping that it would be a clone of the Mazda filter. View attachment 132748
So, going back to this TSB back in the day when the turbo motor was new, the discussion I'm hearing is not about the ADBV but about the *filter bypass valve PSI*... Some of you guys may have heard about Subaru motors "requiring" a filter with a 27 psi bypass valve to make sure the oil keeps getting filtered under high pressure. Well, Mazda specs the turbo engine as requiring a 20.4 psi bypass rated filter. However, it has been shown that under the worst possible case scenario: An OCD grandma using a filter with a 8-11 psi bypass valve on a Subaru "requiring" a 27 psi rated filter, starting her car cold multiple times a day for only a mile of drive at time (to keep checking to see if her mail arrived). There was a photo of her engine at 90k miles and it looked brand new. Since she was OCD she did get her oil changed regularly, so there's that...Skyactive high flow oilfilter
Some aftermarket filter makers do have a specific filter for Subaru applications that spec a higher filter bypass setting.One last thing on the bypass valve psi, it's not known for sure if every filter maker pretty much uses the same spring psi for all their sizes, or certain ones having stronger based on car maker requirements. But it also seems to be based on how sturdy the actual can construction is: filters with a thicker/stronger can, can handle higher pressures...
Easy to switch filters again and see if problem comes back, or offer the used filter that caused issues to someone else for a test run. So, purely anecdotal as some would say here.Interesting discussion on another forum. Cause and effect for one individual.
https://forum.miata.net/vb/showthread.php?t=768183
In general I agree with you… Specifically the Skyactiv is unique. So…. You think the guy is a troll?Easy to switch filters again and see if problem comes back, or offer the used filter that caused issues to someone else for a test run. So, purely anecdotal as some would say here.
I'd wager the thread starter was a troll. I find that many use "Has anyone else experienced...?" similar questions 100's of times with new threads and then simply disappear after creating a thread debate and ad revenue for the forum. AI bots at work.
The real question one should ask is if the oil pump or oil system has its own check valve somewhere. If it doesn't, then you can debate about the ADBV all you want. Give it a remote filter mount, use a PH8a or equivalent, and argue the 8psi bypass and nitrile ADBV. Should get verbally violent in no time.
I am glad I never jumped on the Mazda/Subaru/Hyundai/.... must use their filter or else scare fear tactics bandwagon. All my engines run aftermarket filters, cross referenced oversized options when available, and some ran remotely mounted filters, some had canister conversions from cartridges too, some gained 15psi from balance shaft removal.
Even when a bypass event is triggered, there is still flow thru the media. Its not like the media is instantly shut off and too many think that.
If I have a make-believe 10 gpm filter and my pump sends a make believe 11 gpm thru it, then only 1 gpm is bypassed. If the filter media loads up and drops to 6 gpm flow, then the other 5 gpm bypasses. That flow will keep the media contents from washing out by the bypass flow. So, I am no supporter of the front mounted bypass valves either.
Browser or google translator should help you see a bypass experiment. Your filter is in bypass more often than not and a few extra bypass PSI isn't going to save you. With the amount of VVT screens with crud/sludge, I guess someone at some automakers thinks that a higher bypass will prevent VVT errors until after the warranty expires, especially with foolish automaker OLM and oil change intervals. Its a stupid statistically warranty game every day at your automaker.
https://abw.by/news/experience/2015...aslyanyi-filtr-rabotaet-vsego-2500-kilometrov
That thread is all over the place, lol. If the engine was idling at 1500 RPM after warming up then something is wrong with the idle control system, or something else beside the oil & filter is causing it. Then he did an oil change and the idle went down to 750 RPM when warm and that's what it should be. So he's thinking the oil filter caused the idle to go from what it shouldn't be to what it should be ... what a mess of confusion going on in that thread.Interesting discussion on another forum. Cause and effect for one individual.
I have used Fram and Mobil 1 (older Champ Labs) on 2.5T Skyactiv engines, and there have been no issues with idle quality.In general I agree with you… Specifically the Skyactiv is unique. So…. You think the guy is a troll?
The crankcase and intake vacuum are two different things. You have the oil change and filter change as variables with the filter being aftermarket.I have used Fram and Mobil 1 (older Champ Labs) on 2.5T Skyactiv engines, and there have been no issues with idle quality.
That guy may not be a troll, but he very quickly dismissed the idea of a vacuum leak due to oil cap not being closed or seated properly. I can’t see any reason at all why it would be the oil filter.
The oil and filter isn't going to effect the intake or crankcase vacuum/pressure level.The crankcase and intake vacuum are two different things. You have the oil change and filter change as variables with the filter being aftermarket.
