I thought ELT are also fitted to boats. I am assuming it is designed to float and also designed to go off when it detects impacts. I understand that once it reaches at the bottom of the ocean, it will not be able to send out the signal to satellite but before that it could.
Obviously you believe that ELT does not work once it touches salt water. Can your provide a link for that?
About the Cospas-Sarsat Search and Rescue System
Orbiting high overhead every minute of the day is a worldwide network of polar-orbiting and geostationary satellites. Together with Russia's Cospas spacecraft, they make up the high-tech international Search and Rescue Satellite-Aided Tracking System known as Cospas-Sarsat.
Cospas-Sarsat has been credited with nearly 30,000 rescues worldwide. The system relies on signals received on the 406 MHz frequency to pinpoint position and speed rescuers to the scene of an emergency on land or at sea.
In fact, the more reliable, digital 406 MHz frequency has become the de facto internationally recognized distress frequency. Using the 406 MHz frequency, modern signaling devices can quickly beam GPS LAT/LON coordinates to orbiting satellites. This frequency also allows a position fix through Doppler shift to acquire a location even when GPS can't.
As of February 1, 2009, satellite processing of distress signals from the older 121.5 and 243 MHz emergency beacons was terminated worldwide due to unreliability and false alarms. When a 406 MHz beacon signal is received, search and rescue personnel can retrieve information from a registration database.
This includes the beacon owner's contact information, emergency contact information and details regarding the specific trip plan and any medical conditions of the owner or members in the party. Having this information allows the Coast Guard, or other rescue personnel, to respond appropriately. NOAA, along with the U.S. Coast Guard, is strongly advising all mariners, aviators and individuals using 121.5/243 MHz emergency beacons to make the switch to 406 MHz in order to take full advantage of the Sarsat system.
Cospas-Sarsat is maintained and operated by governments all over the world, thus there is no subscription fee required for owning a 406 MHz EPIRB, ELT or Personal Locator Beacon.
- See more at:
http://www.acrartex.com/landing/rescue/#sthash.BFD0p63K.dpuf
